Question about Dishwashers
Neff dishwasher S55T59X0GB/16 model - Dishwashers
I need help with the program on my neff dishwasher
google manual your make and model #, press the helpful button
Neff Dishwasher Problems
Jan 12, 2016 | Neff Dishwashers
NEFF Dishwasher problem
What model number?
May 13, 2013 | Dishwashers
Neff S41E50W0GB Installation Instructions
Here is a dishwasher manual search engine, they will find the Neff user manual within minutes. Just send them a search request for your model.
Aug 11, 2012 | Dishwashers
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
Feb 28, 2011 | Neff S5946 Built-In Dishwasher
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher trips the electricity
It could be faulty wireing in the dishwasher connection or you could have a leak in the washer causing the wires to get wet. I would have an electrician have a look at it.
Dec 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff Dishwasher
Telephone BSH 08705 543210 ask for spares department who are very good helping you with spares as long as you have all relevant serial and product numbers it can sometimes be difficult to get through because they are always busy, be persistent
Aug 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff built in dishwasher model no: S4453N0GB/07 When you switch the dishwasher on all the relevent lights swich on, indicating the dishwasher is ready to use. but when you switch the start button it clicks...
We fixed the problem at home. The Start button had a loose connection.unscrewed the panel and pushed all the wires in and were able to restart the dishwasher.
Feb 29, 2008 | Neff 24 in. S4456 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
