Question about MSI Wind Top Ae1920-002us All-in-One PC
COMPUTER TURNED ITSELF OFF NOW WON'T TURN BACK ON
Was on computer when it just turned itself off no shutting down just like there was a power cut now it wont turn back on!!! any ideas? can it be fixed? thanks
    Top Expert:
  • MSI Master
  • 41,752 Answers
Your computer could have suffered a complete power failure.
Posted on Dec 31, 2013
Advent Q200 Quantum
Unplug, remove battery, leave battery out, plug in, reboot and try a System Restore to a date before this issue.
May 28, 2013 | Computers & Internet
My computer keeps switching itself off and won't swtich back on again? What can be the problem?
Hello
By know you should of fixed the problem .
1. keep the inside cabinet clean.
2.If the unit keeps shutting down by itself after a certain time and it is not dirty inside the cabinet .Also all the intact screens are clean . Check your Personlization settings By right clicking on your screen . then right click Screensaver and then power settings . Then check to make sure all the settings are turned off unless you want the computer to shut down after a certain amount of time
Oct 30, 2012 | LG Computers & Internet
COMPUTER TURNS ON AT 12AM/NOBODY ON IT?
Check for power options you might have some hibernation settings or some wallpaper wakeup program. If you properly shut down your computer, it won't turn ON itself unless you provide it power.
Dec 28, 2011 | Gateway Computers & Internet
The hub will power down when the computer is turned off how ever it turns itself back on. how do i prevent this
the item you have selected appears to be a USB hub, if it is indeed a USB Hub, there is no way to prevent it from being shut-off when you turn off your computer.
the hub is supplied power from your computers USB port, so when you shutdown the computer, your removing power from the hub.
May 26, 2010 | Belkin ExpressBus (F5U021) 4-Port USB Hub
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Turns off and on by itself
Ok so its connected to your pc?
check settings on the monitor itself [if you'restill able to do that]
disconnect all your usb devices restart your computer and try again.
Is it in a cold room ? that might be the problem.
Is it in the same powerbar as your computer ?
I'm not sure but if your power outlet where you connect it is simply looped to the rest that are in use [lazy electrician] then it might turn off because a power shortage.
Good luck
Dec 21, 2007 | Acer 19" LCD Monitor
MSI Wind Top Ae1920-002us All-in-One PC Logo
77 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
