Question about LG Washing Machines
My washing full of black stuff and washing is dirty
Can you tell the best program for a mixed clothes wash on a bluesky blf 1011
Sorry there is NO BEST just do a normal wash .depending on how dirty the stuff is of course . fixya can not determine what your stuff looks like
Sep 26, 2017 | Washing Machines
My samsung top loader washing machine has black rubber like stuff when washing. How can I remove this stuff?
Hi all of them does it that is the staysoft having a reaction.only thing to do is to full it with water and remove the drian plug at bottom of machine to remove it.hope this helps
Mar 21, 2011 | Samsung SW62ASP Top Load Washer
We have a Bosch SHU3307UC dishwasher. Two friends swear by theirs, saying they put everything in dirty and the load always comes out clean. That does not at all work for us. My wife has to just about wash...
Put dirty stuff in will eventually keep a tech like me very busy. We love to come and charge you alot for cleaning your dishwasher. Remember the Maytag commercials where they put a cake in it? Still got the dishes clean but before long it will cost you big time. Just run everything under the tap. Pot and pans should be lightly washed also. Watch how you place the dishes. Most dishwashers spray up from the bottom. Block it, and the spray will not reach the top.
Nov 28, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Dishes are still dirty. I have used every kind of dishwasher aide, half loaded it and dishes are still dirty, I let the water run until very hot before starting the washer. The washer says you don't have...
Suggest the problem may be a plumbing issue - likely substantially blocked drain system, so the dirty wash water cannot properly pump out but rather remains in the dishwasher.
Suggest getting a plumber in to "snake" out your kitchen drain system. You will probably notice your sink drains will suddenly work much better too...
Aug 02, 2010 | Dishwashers
Dirty washing
Does your washer smell? Is your rubber door seal gungy too?
If so then use 1/2 cup of Washing Soda Crystals (50p for a 1kg bag from most supermarkets)
set washer to 60 degree wash and run machine for full hot cycle with no clothes in it... just the Washing Soda.
I did this with my washer which literally reeked, and my friends have since done theirs and the results are amazing...
Go and check your drain when you finish too... mine sparkles now and it was gunged up before.. I now add a desertspoon of Washing Soda to every wash.... I place it in the crease of the door seal and little by little all the mould is disappearing, even though the hot wash cleaned the gunge the black spots remained. My washer smells so clean now and no more black flecks on the clothes either... (these are loose gunge from the outer drum, right inside the works of your machine...)
All the best
Sue
Aug 02, 2008 | Hotpoint WF430 Front Load Washer
Black stuff in washing machine
You need to clean the filter out (look in your machine - it's on the side of the tub) then run a wash with a cup of vinegar in it (or on soak with napisan or something like that in it). It's just gunk build up.
Jan 28, 2008 | Washing Machines
Black spots and marks on laundry
maby sumthing in the line on the hose dirty tar sumthing weird comming in or are u waching alot greesy clothes
Jan 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Spots of Grey lint left on clothes after washing
Have you cleaned the filter on the front bottom of the machine?
May 11, 2017 | Bosch Washing Machines
Washing Machines Logo
13 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
