Sunbeam manual for mineral water pot 16l - Heating & Cooling
Sunbeam bistro cooker, does it need water in the compartment under the cooking pot?
if this is a ceramic pot in an aluminium case , then no it does not
it works by induction and any water in there will cause problems
Sep 03, 2015 | Sunbeam Crock Pots & Slow Cookers
Can I use distilled water in my Sunbeam ultrasonic sul496?
You most definitely can. In fact it's better than using tap water. As it doesn't have all the minerals and chemicals that tap water has, that cause scaling.
Thanks for choosing FixYa.
Sep 09, 2011 | Sunbeam Ultrasonic Humidifier
I have two and both are having problems! The first one - when I put a whole pot of water in only a half pot comes out. If I put another whole pot of water in on top of that still only a half pot comes...
  • The sprayhead may be clogged. Check the round disk (sprayhead) above the brew funnel. The holes in this part must always remain open. If they are clogged, remove the sprayhead and clear the holes using a toothpick. Always unplug the brewer before deliming or cleaning the sprayhead.
  • The brewer could be clogged with mineral deposits. See the Deliming Instructions in the Manual. NOTE: The frequency of deliming depends on the mineral content of your water.
May 16, 2011 | Bunn VPR Coffee Maker
I misplaced my manual for my sunbeam model 1128 warm mist humidifier and would like to know how to clean it....there is a white powdery stuff coming out of the base, how do i get rid of this....or could a...
the white powdery stuff is minerals, use a vinegar solution to warm water 1 part vinegar to 4 parts warm water. let it soak in the humidifier overnite or during the day and rinse with warm water. You could also use clr using bottle directions.
Dec 03, 2010 | Vacuums
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
Broken coffee pot
Couldn't find any official Sunbeam site with replacement coffee pots. Here's the Sunbeam homepage. http://www.sunbeam.com/Category.aspx?section=kitchen&cid=243 Maybe you could use the contact us link at the bottom and ask them if they sell them separately. Otherwise, you might have to search on ebay or another site like that for a replacement pot.
Hope this helps you.
Dec 04, 2008 | Sunbeam 6385 Coffee Maker
Sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Jan 21, 2008 | Sunbeam Tea Drop Tea Maker HTM5B
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
