Question about Sony DVP-CX860 Multi-disc DVD Player
Cant play All DVD - Band of Brother Has 2 Part on A Single DVD Part 1 Part 2
Hello Im looking For Help for the DVP-CX860. I just bought it off Ebay along with the orginal Remote and manual from sony . Im looking to Has the player Play all the 300 disc i have in it < All play button>. But im looking To fiugre out how To play Certain disc in this mode as well. Some EXeple of issuse i have Band of Brother Has 6 Discs Disc 1 has - PArt 1 And Part 2 And Sp. FT on it < sida a only> Disc 2 has - PArt 3 And Part 4 And Sp. FT on it < sida a only> Disc 1 has - PArt 5 And Part 6 And Sp. FT on it < sida a only> Disc 1 has - PArt 7 And Part 8 And Sp. FT on it < sida a only> Disc 1 has - PArt 9 And Part 10 And Sp. FT on it < sida a only> Disc 1 has - PArt 1 We Stand Alone < Side A Only> also The mighty Ducks Side A is mighty Ducks 1 Sp. Ft Side B is Mighty Ducks 2 Sp. Ft Gettyburg Side A Has Chapters 1 -20 Side b Has Chapter 21 - 40 Im looking for a Step by step
  • 3 Answers
There is a button labeled FLIP on your remote control. It is on the far right column, and it is the fifth button from the top. It is also the first black button on the remote.
There is also a FLIP button on the front of the unit in the top right corner. It is white. When you push it, it lights up orange.
If the unit attempts to read on side of the disc and fails, it will rotate the carousel 180 degrees and automatically attempt the read the other side of the disk.
Posted on Jan 08, 2010
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
My DVP-CX860 has never opened, only the ON button turns on and nothing else happens, since i bought it. Anybody can help?
Is there a transit screw in the bottom? It (they) need removing.
If you hear a little motor straining to open the tray when the open button is pressed, there is something jamming it. In a new machine, there are usually transit screws.
Read the manual, looking for unpacking instructions.
Jan 10, 2012 | Sony DVP-CX860 Multi-disc DVD Player
Sony dvp-fx811 portable dvd player, use to work fine, unfortunately it may have been dropped but was in a soft carry case, now either a dvd wont play and the player says "cant read disk" or if it does play...
Sounds like the optical drive either needs 1 of 2 things. (1)Try cleaning the optical drive with a cleaning kit (2) replace the optical drive. However it may cost more to replace/repair it that it is worth...
Aug 03, 2010 | Sony DVP-FX811K 8 in. Portable DVD Player...
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
My Sony DVP CX860 DVD/CD player is jammed
You can unscrew the top panel. (Two screws on either side, three along the top in the back.) That will allow you access into the unit.
Inside the unit the lense and spindle are encased inside a shell in the center. If there is a disc jammed in there it will require some effort to get it out without damaging your machine. Be sure that it is unplugged to avoid a shock and I would simply attempt to fish it out through the front or back slot.
There's also the possibility that if you unplug it and replug it, the machine will eject the disc if you loosen it up or get it back on track.
Aug 19, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Jan 18, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Sony DVP-CX860 Multi-disc DVD Player Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
