Question about Mitac Mio P550 GPS Receiver
How to change battery on p550 - Mitac Mio P550 GPS Receiver
I formatted my p550 and I don't know how to bootup or reinstall the O/S
You'll need to find the firmware (ROM) image file (Google) and then: Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver"
6.open the software "dnw5.0e"
7.(if you want to make a test of connection USB, click the" USB
port/Statute". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0"
9.press the reset button to restart the mio p550.
Feb 22, 2010 | Mitac Mio P550 GPS Receiver
MIO P550
oprn that folder and there you find the licence detail and fill in the licence detail and then turn off and turn on device and it will be done.
Dec 05, 2007 | Mitac Mio P550 GPS Receiver
I have a Mio P550 Digi walker. How do you open the battery chamber in order to change the battery? Many thanks cacameron@btopenworld.com
I removed the rubber infill that covered a hidden screw. Released screw and then removed back plate. Removing the battery then required care as it is stuck with two sided tape to the Mio internals. Here I used a knive to prise/cut free.
Sep 14, 2009 | Mitac Mio P550 Pocket PC
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
Mio p550 not recocnized sd cards
Try this : Open your device ( it have 5 screws). Inside next to the sd card reader are two metallic sponges. Take them off ( they are glued on some electronic parts and it's shorting the circuits)
Mar 13, 2009 | Mitac Mio P550 GPS Receiver
MIO p550 will not turn on
hi
i think you must know the difference between hard and soft reset.
soft reset is the small hole you put the edge of your stylus to reset the device without erasing anything. (software restart)
hard reset (hardware restore) is:
switch the on/off slider button to OFF. keep the joystik pushed UP and without leaving the joystick slide the from OFF to ON and wait about 30 seconds.
do all that while connected to the power charge. I'd prefer you do that with a wall charger, and not with a USB cable connected to your computer (we dont like this charging state from USB ports)
let me know what happened after that. if possible, upload a video showing us what you did.
thanks
Gery
www.nextlab.co.il
Mar 02, 2009 | Mitac Mio P550 GPS Receiver
NO COLOR-JVC UX-P550
chnge the colour system of your player to auto mode .read the instruction manual.
nuwan
Nov 21, 2008 | JVC UX-P550 System
Mio p550 wireless N security connectivity problem
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
BSL
Oct 03, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
http://www.mio-tech.be/EN/support/support-overview.php
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Courage,
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 how do i do a hard reset
on/off switch in "off" position for at least 30 seconds, then turn it in "on " position, power on and "reset". You'll lose all your data and all the installed programs.
Alternative: using the screen options, go to "system info", and choose "hard reset".
Beware: pushing the joystick down while doing a reset will get you a boot menu with memory-formatting options. Choose "exit".
Otherwise look into xdadevelopers forum (Google it or go to, say,
Mio P550 / P350 ROM upload [Archive] - xda-developers
A good idea would be to backup your data in the first place- just a hint.
Enjoy.
Dec 09, 2007 | Mitac Mio P550 GPS Receiver
Open Questions:
See all Mitac Mio P550 GPS Receiver Questions
Mitac Mio  P550 GPS Receiver Logo
16 people viewed this question
Top Mitac GPS Experts
Ed Mac
Greg Cann
Greg Cann
Are you a Mitac GPS Expert? Answer questions, earn points and help others
