Question about Wine Enthusiast Matrix Wine & Beverage Cellar 2-Drawer Dual Zone
Wine fridge not cooling
The lcd display indicates the fans running,which they are the compressor icon in both zones in cooling mode.I can visually see all the fans working and can hear the compressor running.The temp inside the zones are 64f and the temps are set to 40f and 50f which call for cooling.I have left it running but the temp inside both zones is not cooling.The compressor runs and in about an hour gets hot and gurgling can be heard coming from it.It is only a year and a half old and everything else works great.
  • 1,885 Answers
Or a program timer clock electronic-assembly or solenoid valve problem or in the worst case empty by leaking refrigerant.
cooling fanproblem the fanblade(s) must turning very flexible.
Posted on Dec 09, 2016
    New Friend:
Turn it on
Posted on Dec 31, 2013
  • Paul Williams
    Paul Williams Aug 21, 2014
    compressor does not run power seems to be up on wiring to compressor connectors
Sub Zero 642 side by side, refrigerator side not working.
If the refrigerator compressor runs and cools when you use the manual activation mode but does not run normally then the control board would be what I would suspect. If it has the manual activation then it is new enough to give error codes. If it is not running and not recognizing it's not running, something is wrong with the control. Unless you are seeing two dashes in the refr display. That would mean the refr section was disabled.
Jan 11, 2016 | Sub-Zero 642
Why is there an occasional rattling sound from the rear?
Good afternoon Bob.
Wine coolers have a lot in common with mini-refrigerators. The cooling for the wine, to proper 'cellar' temperatures is done gently (one hopes) with circulating cool air that should keep the temperature stable, and the dust to a minimum.
The fan you hear is most likely one keeping the refrigerant compressor cooled off. Depending on how your unit is packaged, what you'll likely want to do is
  1. Unplug the unit. No pokey pokey into the guts of things plugged into the wall. Always err on the side of safe. Aside from shock rick, the small fans in fridges can actually cut fingers up pretty good if you let em.
  2. Look to the rear lower section of the unit and find the compressor(s) and associated fans and perhaps cooling coils. Much like with regular fridges, use a brush or a vacuum attachment to clear any dust bunnies or other debris off of the coils, compressors, and fans.
  3. Examine the fans. See if anything may have been sucked up into the blades or spindle - giant cobwebs, bits of thread of carpet fiber. See if the blade will spin freely, and whether it feels loose. If it won't move, or is obstructed, try to clear it and clean off any debris or fiber. If it will not move, the fan may have failed. You don't want to run a fridge this way, as the next thing to go after the cooling fan for the compressor is the compressor. At which point most honest techs will say 'buy a new fridge, I can't replace it for less than the fridge will cost you.
  4. You can also see if there is anything else obviously loose near the compressor or fan. There's a significant power surge needed to start the compressor, and the initial slow cycling may be making things shudder.
Hoping this is useful. Good Luck!
Nov 18, 2015 | Furniture
Fan runs, control panel lights up compressor not running unit not cooling. Any ideas as to why compressor not running?
could be a start run capacitor failed
I suggest that you get a fridge technician to check ti out first as a compressor is generally more expensive than a new unit.
Aug 03, 2015 | Furniture
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
I have 2 zones, both of which are programmed. The display for zone 2 works fine. When I am looking at zone 1, the desired heating and cooling temps display as -- with no temps there. The system is set on...
Are these reading temps at 2 separate tstats or are you using temp sensors that send the temp back to the stat. It sounds like the sensor is not communicating with the stat.
Jun 14, 2017 | Carrier 38CKC042 Air Conditioner
AC fan runs when heater is turned on in RV Dometic single zone
the heat and cool use the same fan. if compressor is running with heat then you have relay issue
Jul 05, 2013 | Dometic 3313192.000 White Single Zone LCD...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
Samsung model rs267 says OF on both temp displays
Freezer and refrigeration isn't working
There is no temperature indicating for Celsius of Fahrenheit it just displays OF.
The letters "OF" on the display of your refrigerator indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and the display returns to normal, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air. Thanks-Helpful?
Feb 07, 2011 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Wine Enthusiast Matrix Wine & Beverage Cellar 2-Drawer Dual Zone Logo
785 people viewed this question
Top Wine Enthusiast Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Wine Enthusiast Furniture Expert? Answer questions, earn points and help others
