Question about GE Profile Spectra JGBP79 Gas Kitchen Range
F2 flashing on screen of my GE Spectra oven.
Sometimes when I heat oven up it starts flashing F2 on the screen. What does that mean? It usually goes away when I turn of oven but tonight it didn't. ! had to unplug the oven because the beeping & flashing didn't stop/
  • GE Master
  • 3,361 Answers
Your oven temperature sensor has failed and must be replaced.
Posted on May 28, 2009
  • steve
    steve May 28, 2009
    Part number WB20K0004.
    Average price $100.00.
One controller keeps flashing F2, what does this mean. It will not go to any setting on/off , raise or lower heat setting, etc.
All the information is here. It is a heating sensor error. There is also a video.
If you have a GE oven with an electric ERC, F2 means it is over heating. It is an oven. It is supposed to heat up. For the GE electric ovens and some others, F2 means it thinks the temperature is 590 degrees or higher with the door unlocked or 990 degrees with the door locked.Oct 11, 2015
F2 Google Search
Dec 10, 2016 | Ovens
I have a GE oven, model #JTP15W0W2W, serial #SS605844R that the bottom heating element does not work and the screen flashes F2. I contacted GE and they recommended I change out the bottom heating element,...
Ge should know their own codes. F2 for GE means oven control senses overheat over 600 degrees
Go here for code desciption . You should be able to fix youself
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
best of luck
matt
Aug 15, 2011 | GE Ovens
Flashing f2 preheated on a ge-spectra
F2 fault code indicates the oven exceeded 590 degrees with the door unlocked. This could be caused by a stuck relay on the oven control board or it could be caused by high resistance in the oven temperature sensor probe.
Feb 20, 2011 | GE Profile Spectra JBP95 Electric Kitchen...
Oven will not come on. Display screen flashes F2.
The error code means that bad relay on control board.
It could also mean that sensor is not making proper
connection with the board.
Sep 01, 2009 | GE Ovens
GE true temp oven f2
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Jan 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven cuts off and code f2 whats this?
This means your oven is over heating - easiest solution change control board - if you understand more - usually caused if the contacts on the relay are welded (stuck) together.
Aug 31, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
F2 error
I have the same problem... I unplug the range wait 30 seconds ...the plug it back in..usually works. Remodeling soon .. next range not GE!
Sep 09, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Range Spectra oven not working
F2 is an indication of an oven temperature sensor problem. Usually this is a problem with the oven sensor itself, or the relay contacts on the Electronic Range Control (ERC) board. If you had a close lightening strike, I would suspect that the contacts on the ERC are probably bad. It probably wouldn't hurt to replace the oven sensor as well. I hope this helps you.
Jun 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
656 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
