Will not start
Digital display flashes -0- and the start button flashes and beeps, when pushed the key light flashes
    New Friend:
Unplug it for a minute and then plug it back in
Posted on Dec 31, 2013
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Posted on Nov 09, 2008
  • 249 Answers
SOURCE: Zanussi 1431 - All lights flash when push any button.
leave it unpluged for one hour,then try again
Posted on Dec 01, 2008
  • 91 Answers
SOURCE: washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
Posted on May 28, 2009
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Disonnected the radio then when I put it back SAFE comes on then I press the two buttons and wait then I never got this before I get a 1 and 1000. Then I push the #1 on the radio and get 0000...
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from an Volkswagen dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for 1997 VW radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "3560". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 3 times on the no.# 1 button. The "3" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 5 times on the no.# 2 button. The "5" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 6 times on the no.# 3 button. The "6" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 10 times on the no.# 4 button. The "0" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Aug 12, 2011 | 1997 Volkswagen Jetta
I have my code but I can't take the SAFE out. Can anyone help please??
The sequence of programming for 1999 VW Beetle radio is:
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Mar 23, 2011 | 1999 Volkswagen Beetle
I have a AW60448W stopwatch that I can't get the alarms to turn off.
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: NowPrinting@BellSouth.Net if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Dec 28, 2010 | Watches
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
How do i clear the maint reqd light on 2006 toyota carolla
With key off hold down the trip reset button and turn key on while holding it. You will see 5 small lines counting down to 0 on the odometer display. When it gets to 0 it is reset.
May 17, 2010 | 2006 Toyota Corolla
Reset prosedures for volvos
Ok when you move the key to start the car. you need the following definitions.
pos 0 equals car off
pos 1 equals acessory position
pos 2 equals run position (NOT START)
pos 3 equals start position
check your drivers information module, and see that your triip display is in trip 1 (T1)
then put your car into position 1. push and HOLD the trip reset meter. WHILE HOLDING the reset button, rotate the key to position 2. Hold the reset button until you see the triangle in the dash flash yellow. Once this starts flashing remove your finger from the reset button. Shut the car off, verify light is out. repeat once if necessary.
Jul 22, 2009 | 2004 Volvo S60
Sharp Z-830
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Nov 21, 2007 | Sharp AR-5316 Advanced Digital Imager...
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
