Question about Staples SPL638X (CrossCut) Shredder
Clogged teeth clean sh2106pa - Staples SPL638X (CrossCut) Shredder
I wanna know how to fix Andis superliner clippers.mine just simply dont cut anymore??someone please help
If the clippers stopped cutting, they are probably clogged with hair on the inside of the clippers. I had two pairs of clippers where this happened. I took them to be serviced at a beauty supply store and they cleaned the hair from the inside of both pairs of clippers for me and they now work just fine.
Jul 12, 2014 | Andis SuperLiner Trimmer 04810
Tip
Cleaning Clogged Print Heads
I have had very good luck cleaning dried or clogged printheads by using a waterpick. The litle pressure washer for your teeth. Just wash the nozzles with the waterpick. Sort of a miniture pressure washer. It can get you wet so its best to hold the cartrige in some sort of container to prevent getting to wet. Wash long enough to dislodge the dried ink, or soak the cartrige for a while befor cleaning.
on Oct 05, 2010 | Office Equipment & Supplies
Align blade
Bob,
I just bought one of these saws 2 weeks ago (1997 Model) I have it completely disassembled as of right now. There is a worm gear that drives a very large set of teeth attached to the trunion. Mine were completely clogged and full of crud that the mechanisim would barely turn. I am thinking the teeth on the worm gear or trunion at the 90 degree end need to be cleaned to allow it to hit its full range of motion, Its also possible the teeth on one of these pieces is cracked or broken. I would try cleaning them. If you cant get to them, the cast iron top comes off fairly easily. # bolts hold the right wing to the main top and 3 bolts hold the main top to the cabinet. Of course if you have rails, these need to come off first. I have attached images of the before and after of cleaning these parts so you can see if they are really bad like mine, it could be your problem, Hope this helps de3088fd-0aec-4075-8706-9fa0612a5ce0.jpg bc25b745-d28c-4458-922d-16905057df8c.jpg c29ab931-39d0-48dc-924f-4f3c8ea89dea.jpg b2fc31df-9a04-4496-8466-c01e4fcc2471.jpg
Jan 14, 2014 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Line spins out from rapid loader and doesnt stay put. has happened with 3 units after using for a short period of time
I've been using these for years! It shouldn't happen after only a few uses! Make sure your line is at least 3/4 of an inch inside the trimmer head! If you have been doing that the teeth are clogged! Take it apart and use a triangular file to clean the teeth!
Jun 17, 2011 | Echo Rapid Loader, Trimmer Head
Shredder will run in reverse mode but not in forward/auto. Has not been jammed or overheated.
Unplug the shredder. CAREFULLY clean out the shredding teeth and paper pathway. On some models you can loosen one end and open the paper path for better access. Ther is an acuator arm for a switch at one edge of the paper path and that will get clogged with paper and the arm cannot move to tell shrdder paper paper is in, ready to go. A blaast or two of canned air in the direction of the arm will help too.
The reverse action is ususlly initiated manually and is not affected by switch operation.
Let me know
Jan 15, 2011 | Techko SH2106PA Shredder
The top rack does not get clean. There is a dirty
Most likely the "food grinder" screen is clogged, which limits the flow throught the pump, leaving thehigher dishes unwashed. It's flaw inthe design of whirlpool/kitchenaides. Not only does the screen clog but the teeth on the "grinder" wear down, the girneder does no grinding, and the food particles build up onthe screen, clogging the water flow. Open up the collector, pul out he choer/grinder and clean the screen. Check the teeth on it and if worn, repalce the chopper/grinder. If it happens again , then the choper/grinder driving mechanism is basd -- replace the pump/motor assembly.
Feb 21, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
Shreddar not starting
Clean the sensors and the machine indor unit.
Sep 25, 2009 | Techko SH2106PA Shredder
Techko SH2106PA
your blades have either become dull or have spread due to a jam or a broken mount on cutter if your in warranty contact manufacturer if not time to buy a new machine.
Dec 14, 2007 | Techko SH2106PA Shredder
Need Information:
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Oct 09, 2007 | Techko SH2106PA Shredder
Staples SPL638X (CrossCut) Shredder Logo
74 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
