Question about Black & Decker Black And Decker 12 Volt Battery Charger 5101181 01
The light don't come on and want charge my 12 volt battery
How to fix a 12 volt black&decker battery charger?
  • 360 Answers
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
Posted on May 20, 2009
2 Suggested Answers
clyde2j2
  • 137 Answers
SOURCE: Black & Decker 24 volt battery will not hold a
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
Posted on Mar 02, 2009
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
I have a firestorm double 14.4 charger. Both lights come on but neither battery charged. The charger does not get warm.
Take a volt meter and test the connections where the battery comes in contact with charger. If you have no voltage, then the charger has failed and needs to be replaced.
Aug 25, 2011 | Black & Decker Black And Decker 12 Volt...
How long do I charge the battery for 18 volt black & decker weed trimmer
put it on the charger and plug the charger into an electrical outlet ...
Jul 12, 2011 | Black & Decker String Trimmer Cordless 12"...
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
Jun 28, 2011 | Black & Decker Pivot Plus Cordless...
How do I know if my battery is bad or if my charger is bad? The red light on my charger no longer lights up when I plug it in. This is for my Black & Decker Firestorm 12volt drill. Thanks
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
Nov 08, 2010 | Black & Decker Black And Decker 12 Volt...
Charging light does not come on, is it working or not
usually not, but could be one of the LED light burnt out though I don't believe so. Do you have a volt ohms meter that you can check voltage coming from the charger contacts to verify the operation.
Oct 17, 2009 | Black & Decker Black And Decker 12 Volt...
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
Black & Decker Black And Decker 12 Volt Battery Charger 5101181 01 Logo
1,373 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Rabbit Brains
Rabbit Brains
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
