Question about Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487
Northern tool brand wire fed gasless welder feeds wire fan work no welding?
My northern tool wire fed welders gun feeds wire fan turns on but no welding?
  • badenhop
    badenhop May 11, 2010
    Have you checked your ground? Do you have the positive & negative terminals inside properly connected?
  • Brad Cliburn
    Brad Cliburn Dec 28, 2013
    Will check
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 3 Answers
You need to have the ground attached to what you'll be welding on. Make sure there isn't anything on the end of your wire. Also, if your voltage is all the way down it won't do anything either. Oh, one more thing, make sure you have a contact tip on the end inside the cone. That will be the copper thing the wire goes through with a really small hole. I know some of this sounds pretty obvious but if I hadn't done these things at least once.....I wouldn't know what to look at either. I also don't know your experience level and want to cover all avenues. Hope you find it!
Posted on Jul 02, 2009
  • Brad Cliburn
    Will check thanks for the advice.
My welder won't feed wire it sounds like it's trying to energize but can't. A couple of times it fed through but wouldn't feed to weld so I had stick weld. What happens if the liner has a restriction?
first unscrew the tiny tip at very end of torch (can be hot)!! then try to feed wire thru handle,gently shake cable as you do helps to feed wire thru cable , if successful you have allowed the amps to get too high for the feed rate (slow) and melted the tip closed , these tips are replaceable from miller and are not expensive
Aug 09, 2016 | Miller Multimatic 200 MIG TIG & Stick...
I have a kende mig 105 gasless welder,but the wire isn't getting fed through on the feed wheel,tried different welding wire and also turned the wheel,tried tightening the wheel,slackening it as well,i
Here's a few things you can check:
When gun trigger is pulled, do the drive wheels turn? If they aren't, pull the trigger again; do you hear anything within the machine (contactors closing, gas solinouds opening, any clicking, etc.) that would indicate the trigger circuit is functional?
If the drive wheels are turning, but wire isn't being pushed thru the mig gun, check for proper drive roll vs. wire size. If that is correct, check gun liner for obstructions. Flux cored wire tends to stop up a wire liner fairly quickly.
Dec 21, 2014 | Welding Tools
Why wont the wire come through my cosmo gas gasless welder
Most mig welders have reversible feed spools. There is a good chance you have the spool in the .030 wire side. Remove the spool retaining clip and flip the spool to .023 wire for example. I don't know what size wire you are using. Also there is an adjustment for the drive spool. Tighten the tensioner spring thumb screw to increase the feed tension.
Apr 28, 2014 | Welding Tools
Fan runs but nothing else
check small wire on opposite end of Gun. May not be connected well
Nov 17, 2013 | Craftsman 20568N 85 Amp 120 Volt Gasless...
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Mig gas conversion for JobSmart 125 Flux Wire Welder
The other difference between gas/gasless is the ability to reverse the gun polarity which you can't do with a gasless only welder. You can get it to work but not safely and reliability could be an issue also.
Mar 06, 2012 | Welding Tools
Have solar 110 2172 mig welder does this mig use gas can i use flux core wire also is owners manual available
Yiu can use both innershiel and solid core wire. All you need to do is inverse the polarity for the innershield wire (gasless wire) connect the gun to the ground and ground cable to positive side.
Dec 26, 2010 | Solar Mig Welder Welding Gun Liner Parts...
I have a century powermate 70 mig welder and using .30 fluxcore wire. the machine says that it is gasless also. the machine will not weld right. is this the right wire or what could be wrong?
Check that your ground clamp connection to the weldment is secure (tight).
you can weld with the shielding gas, or without.
by not welding right, what exactly do you mean?
Jun 29, 2010 | Welding Tools
Welder will only weld for about three inches on high
If it won't push wire through gun you might need to tighten wire rollers, or check the liner for bad spots.
May 13, 2010 | Century 80GS Flux - Cored Wire Feed Welder
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487 Logo
288 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
