HP laser printer Will not print ink spilt on components
Printer was tipped and ink ran over the components ,want to know if Hp model 5600 are compatible?
    Top Expert:
  • Computers & ... Master
  • 23,210 Answers
Compatible with what?
Posted on Dec 31, 2013
  • 85 Answers
SOURCE: cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
Posted on Nov 16, 2007
  • 4 Answers
SOURCE: Macintosh Printer Driver for HP Deskjet 712C
Try downloading GutenPrint 5.1.4 It is a collection of open source printer drivers. Based on reviews and comments, it seems to have worked with older printers.
Posted on Dec 25, 2007
PegBox60965
  • 51 Answers
SOURCE: print spooler service not running on Windows XP
Spooler depends on the RPC service being running. But you really need to get into event viewer and check for anything related to either RPC or Print Spooler. If you're trying to print to a network printer you could have firewall issues either within Windows or your router. Think about what changed on your system around the time this problem began.
Posted on Jan 01, 2009
T-Mania
  • 42 Answers
SOURCE: printer port for my new hp pavilion dv7?
You should be able to use a parallel to usb converter heres one in the link. There hard to find most are usb to parallel but this should work.
http://www.usbtech.com.au/product.php?productID=GW-K200
Posted on Mar 23, 2009
  • 108 Answers
SOURCE: HP Pavilion dv6-1245dx won't connect to Dell Laser Printer 1110
you might not be having updated softwares try installing in compatiability mode or download updated ones
Posted on Aug 19, 2009
HP DESKJET 5600 ENCOUNTERED ERROR WHEN POWERED ON
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or fails to function at all (i.e. blinking ink lights on Deskjet 5000, 5100, 5500, 5600 or 5800 series printers) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
Also verify that the cover interlock switch (at top-right side of printer) is closing properly - you may need to place a thick shim (1/4 inch by 1 inch) into the door switch port to enable printer to properly energize (I would check this first). This Deskjet printer series is known to have a top cover closing issue (the top covers warp over time unfortunately).
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the cartridge nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jun 19, 2012 | HP Office Equipment & Supplies
HP inkjet 5600... can't find where to see ink cartride levels...
Try this
For Windows users: In the HP Solution Center, click Settings, point to Print
Settings, and then click Printer Toolbox. Click the Estimated Ink Levels tab,
and then click Print Cartridge Ordering Information.
manual is here
http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Mar 10, 2010 | HP Officejet 5610 All-In-One InkJet...
HP officejet 5600 connected but not printing
try a complete reinstall of the printer:
1) unplug printer
2) un-install all drivers, and make sure printer is removed from printer list
3) download the latest drivers from HP:
http://www.hp.com/sbso/bussupport.html
(the included CD drivers could be outdated)
4) follow HP instruction on how to install the new drivers and printer (sometimes it wants software first, sometimes it wants to detect printer first).
Jan 15, 2010 | HP Officejet 5610 All-In-One InkJet...
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
Apr 03, 2009 | HP OfficeJet J4580 All-In-One Laser...
My HP 5600 series printer will not print because
check the cartridge head might be hook or the there might ink spillage, put off for some time and on again,
Mar 27, 2009 | HP DeskJet 5550 InkJet Printer
Printer goes throught the motions of printing, but what comes out is a clean page - no ink
I had the same issue when I replaced the printer and kept the old cartridges I had just purchased. The OK button I pressed was on the PRINTER not the PC. You dont say the model printer you have. Mine is an all-in-one J6480.
Oct 24, 2007 | HP PSC 1610 All-In-One InkJet Printer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
