Question about Dell Computers & Internet
PC does not boot
If i push the power button nothing happens. is there a known bug with capcitors?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Hard to say as you don't state what your Dell tag number is. For reference, anyone with a Dell issue, please state your Dell tag number.
Your issue is either the fuse in your power cord so try another suitable power cable or it is the actual power unit of the CPU itself on the basis there is no power light any where
Posted on Jan 01, 2014
4 Suggested Answers
  • 9 Answers
SOURCE: DELL DImension does not boot
http://dell-driver.driveray.com/dell-drivers/s_329_1.shtml
Posted on Sep 26, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Emachine T6426 PC..I push power button and fans
Hello there:
If all of the fans come on, check to see if the fan is blowing on the power supply if it is not than you are going to have to replace the power supply. please keep me informed cause there is more that we can do if needed ok.
best regards mike
Posted on Aug 03, 2009
joecoolvette
  • 5660 Answers
SOURCE: I am looking at a
Bad Power Supply. Weak voltage power rail.
[There are three main voltages produced by the Dimension 4550's Power Supply.
1) 3.3 Volts
2) 5 Volts
3) 12 Volts ]
The Power On button LED functions as a diagnostic light also.
Dell Support > Dimension 4550 > Service Manual,
http://support.dell.com/support/edocs/systems/dim4550/
Left-click on Solving Problems, then click on Power Problems
The Power Supply is just an ATX form factor version. The common Power Supply form factor used in MANY desktop computers.
(ATX form factor for a Power Supply refers to the size, and shape of the Power Supply's case.
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall)
HOWEVER, (Not shouting), there is an area of concern, should you try a Power Supply you may have available for a test, or purchase one.
It involves the wiring of the 20-pin ATX main power cable. More specifically the power cable's connector.
To explain view the standard wiring, set for a 20-pin ATX main power cable's connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Looking at the photo to the far right, observe the color code of the wires, going down into the socket holes of the connector.
Look at the Lock tab on the side of the connector. This will help you orient the color code of the wires, and their placement in the socket holes, to the chart below the photos.
The connector on the end of the 20-pin ATX main power cable, is a Male connector.
Where the wires go into the connector, is the Back of the connector.
In the middle photo you can see the Front of the connector.
The wires going down into the ATX main power cable's connector, end in a female metal terminal.
The connector on the motherboard, (Shown in the photo to the Left), has Pins.
The metal female terminals go over the Pins.
The pins are numbered. The color code of the wires match up to the pins.
This is shown in the chart.
Now look at Dell Support > Dimension 4550 > Technical Overview > DC Power Connectors >
DC Power Connector P1
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101897
The illustration may not be accurate. You'll have to compare since you have the computer, and Power Supply in front of you.
For a time period Dell was a Proprietary manufacturer.
Meaning they wanted THEIR parts used on THEIR computers, and ONLY THEIR parts.
They had the motherboard manufacturers make motherboards according to their specs.
One of the specifications was that the pins would be CHANGED around, in the motherboard connector for the ATX main power cable.
They also had Power Supply manufacturers make the ATX power cable to their specifications.
This means if a user bought an aftermarket Power Supply, the color code of the wires in the ATX main power cable would Not match.
Many users did buy an aftermarket Power Supply, and installed it.
Burnt motherboards, fried Processors, and graphics cards, resulted.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
Black wires are Ground wires.
Guess what happens when you plug a 12 Volt wire into where a 3.3 Volt, or 5 Volt, or Ground wire is supposed to Be?
POOF!
My suggestion would be to look for a Power Supply that is an ATX form factor, is KNOWN to be good, and is compatible, for a test unit.
You, or someone you know may have upgraded to a better computer, and you may be able to borrow the Power Supply for a test unit.
Compatible:
Has the Correct power cables.
1) 20-pin ATX main power cable, OR a 20/24-pin ATX main power cable.
(20-pin connector that has an additional connector with 4 pins. Just use the 20-pin)
2) 4-pin ATX +12 Volt power cable. (Also referred to as P4 MB, and P4 ATX 12V)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
(Power for the Processor)
3) Enough standard 4-pin Peripheral power cables.
(Misnomered as Molex)
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(Power for the IDE Harddrive, and Optical drive/s)
Also:
You can change the power wires around in the ATX main power cable's connector.
Change them around, in an aftermarket Power Supply's ATX main power cable's connector.
Want to know how post in a Comment.
Posted on Oct 09, 2010
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
Power light comes on but nothing happens on start up
Press F8 during the boot sequence and select the last known good configuration, this should negate the updates and allow you to boot sucessfully.
Then apply the updates via the windows update website don't use autoupdates for this very reason use this reg tweak HERE to disable autoupdates for future reference
Pleae rate my help
Oct 16, 2009 | Acer Aspire One PC Notebook
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
Pc wont power up
Are all the installed drives functioning properly?
I've seen this with a bad IDE cable.
It may give a corrupt drive name in bios.
Feb 17, 2009 | E-Machines eMachines Desktop PC
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
HP Laptop
Try this,
Unplug the laptop, remove the battery from the underside (there should be a catch to push, and the battery will pop out). Then wait a few seconds and put the the power cord back in and the battery. Hold down the on button for a few seconds and boot it up.
May 22, 2008 | Computers & Internet
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
