Question about Irulu 7" 4gb Mid Google Android 2.3 Touchscreen Tablet Wifi Usb Keyboard Case Bundle
Won't turn on
Tried the charger and holding down the power button
    New Friend:
You have to get
Posted on Jan 02, 2014
I have a samsung galaxy tab E that won’t recognize its charging adapter or cable. I ordered a new factory specific charger and am still having the same problem.
Hi unplug charger hold down POWER BUTTON FOR 30 SECONDS
KEEP HOLDING BUTTON DOWN PLUG IN CHARGER AND HOLD POWER BUTTON DOWN FOR ANOTHER 30 SECONDS.. cheers
Jan 30, 2018 | Samsung Tablets & eReaders
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Jan 02, 2015 | Irulu 10.1 inch Android 4.0 Touchscreen...
Won t turn on
Have you held the button in for ten seconds? Are you pushing it in correctly? Did you charge it? If the battery goes down it will not come on. Plug in the charger for awhile then try turning it on. If you spilled something on it you might have a problem. So many things we dont know. Try the charger first.
Sep 05, 2014 | Amazon Kindle Fire HD
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
Kindle won't turn non
Try these:
Reset the Kindle
Hold down the power button, or hold the power slider to the right, for at least 20 seconds. Then release the power button or switch, and push it again to turn on the device. If that doesn't work, hold the power button or slider for up to a minute, then release it and try to turn on the device.
Is there a power issue?
When you plug your charger into the Kindle, the LED should turn yellow if the device is charging and green when the device is fully charged. If the light doesn't turn on at all, it definitely signals some kind of power issue. Replace the charging cord if possible.
The Kindle uses a micro-USB connector, the same as most mobile phones. Try changing the cord or if that doesn't help, try another power source - a different charger, or connect it to a USB port on your computer. Finally, gently wriggle the adapter where it enters the Kindle. If the charging port has come loose, this movement may cause the port to realign and the LED to illuminate.
Aug 04, 2014 | Amazon Kindle Wireless Reading Device
My 7" android sky wi fi tablet won't switch on
Will it turn on while plugged into the wall charger? If so, you may have a battery issue.
Try holding the power button to power one while plugged in, if that does not work, press and hold the power button and volume down button to see if it will turn on.
Jul 24, 2014 | Tablets & eReaders
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
Galaxy tab won't charge or turn on
Hold the up and down button and Power on for10 seconds and that should cause the Galaxy 3 to reset. Work for me.
Jun 29, 2011 | Samsung Galaxy Tab Tablet PC
Irulu 7" 4gb Mid Google Android 2.3 Touchscreen Tablet Wifi Usb Keyboard Case Bundle Logo
69 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
