My tv autovox is asking for a key to be unlock
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
I have a RCA tv and I have a LM-620 universal remote how do i make them work
salve avrei un problema con il telecomando da poco acquistato in quanto nella mia televisione autovox non funziona il codice quale codice devo mettere
grazie anticipatamente
Sep 10, 2012 | Philips Magnavox Learning Universal Remote
Tv asking for a key
each brand has a different key You have not said brand or model here
both would be needed to unlock this. Why not go to the manufacturers site and look under SUPPORT for that model and get the manual for it?
Aug 15, 2009 | Televison & Video
Apex tv locked
Let me know if this helps.
May 24, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
How to unlock my Apex TV #at2002 with only KEY shown in the corne
Press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels..
Please rate this Fixya solution
Jan 20, 2009 | Apex Digital PF2020 20" TV
CODE FOR NEO TV 1400 TXV
J have a problem with Neo tv 1400sb, j need code to unlocked?
Jan 04, 2009 | Philips 30DV693R 30 in. TV/DVD Combo
Apex tv want turn over
a small red key is at the bottom please help
May 31, 2008 | Apex Digital AT2708S 27" TV
Tv locked
Im guessing you have an Apex TV. So here it goes:
Answer:According to Apex, you can disable the parental lock using the following information.
One of the above methods should get you past the lock. If so, I would take the opportunity to disable the lock in the TV's menu so this doesn't happen again.
If this still doesn't work, you can call Apex Customer Support at (800)880-1227.
Nov 15, 2007 | One For All URC-3021 Remote Control
Tv t1413 key
What make and model of TV set?
Aug 29, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
