X-Factor LS998 Pedestal Karaoke Machine - Audio Players & Recorders
Won't play the CD and the open cover door won't go off when you close the door
Normally in all CD players there is a little "pip" in the door that presses a S/W when you close it. this may may brokend
May 14, 2015 | Singing Machine The iSM1028Xa Pedestal CDG...
Screen quit working
Sounds like it has taken a pretty hard jar Remember to rate my help and if you need further help just shout thanks in advance. I would open it up and make sure all connections are together and have a space filled that one plug has come undone in the system somewhere this is most likely your problem..
Nov 09, 2013 | Singing Machine STVG-999 Pedestal Karaoke...
Instruction booklets on machine
Many of the Singing Machine Karaoke system manuals are available on the company's support site: http://www.singingmachine.com/support/instruction_manual.php . The direct link to the STVG-1009 manual is http://www.singingmachine.com/download/Instruction_Manual/2010/CDG/STVG-1009/STVG-1009%20IM%20E01%20(SMC%20US).pdf .
I hope this helps.
Mar 24, 2012 | The Singing Machine Singing Machine...
What cord do you need to plug the ipod into the karaoke machine
This depends on the karaoke machine in question. Mostly the Ipod accepts a 3mm earphone jack and the karaoke is supposed to support the regular av in 2 pin jack. so all you need to do is get the single 3mm headphone jack to 2 pin av in jack. that should work perfectly.
Hope this solution has been helpful?
Dec 29, 2010 | GPX Karaoke Party Machine
MY KARAOKE MACHINE
I have the same type Caraoke machine that turns on but it does not play the CD....
Apr 30, 2008 | Audiologic DVCR-251
 Grubhead
Grubhead
