Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Blowing dip stick out freeways
01 roadking classic stage 3 kit having problem blowing dip stick out i do check oil level wich is just above at add quart mark.note i do ride a little hard.
  • 355 Answers
Well did this start after the 3 stage was put in if so you may need to look at the breather timing or do you have the dip stick that has temp gage in it there a couple of different one you could have the rong one Ive seen this before any way if the three stage was put on and it started after that i would go back and check all the breathers hose and any other thing you may have done hope this helps need more info on how far you went with three stage lots of after market stuff out there need to now did you go with harley or what to help good luck redoil.
Posted on May 29, 2009
How to tell the motor oil is filled on the dip stick
The dip stick has markings on it showing the level it should be at.
Jan 04, 2016 | 1997 Cadillac Eldorado
How many inches is oil dip stick for nissan altima 3.5 ltr V6
How you check your oil level properly on a Nissan 3.5 engine
? 1:15
https://www.youtube.com/watch?v=5uih27KiKMo
Mar 2, 2013 - Uploaded by FixyourNissan
When you have no dipstick tube you can incorrectly check youroil level. ... How you check your oil level ...Missing: inches ‎ltr
Oil Dip Stick Reading...Help! - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../92792-oil-dip-stick-reading-help....
Mar 28, 2003 - 14 posts - ‎12 authors
Okay, I have heard that the dip stick is a little wierd. ... I've had no problems checking the oil level in many cars over the years, but the alti really ... Oil Change, dipstick reads above high
May 26, 2012
4.5 or 5 quarts of oil?
Nov 4, 2009
2005 Altima 3.5 liter tranmission fluid change
Sep 1, 2008
Checking the engine oil - w/ warm or cold engine?
May 30, 2007
More results from www.nissanclub.com
Check Oil Level 2002-2006 Nissan Altima - CarCareKiosk
Dec 13, 2015 | Nissan Cars & Trucks
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
Can't find where to add transmission fluid in a 2006 all wheel drive equinox
I am unfamiliar with exact car, however, It is not unusual for transmission oil to be put in via the the transmission dip stick tube - do not confuse it with the engine oil dip stick tube. Do it slowly and make sure you dont over fill or you will eventutally blow your transmission box seals or worse. Let the oil settle before checking levels too because it is easy to misread the dip stick when you have used the dip stick tube to fill oil in.
Jun 04, 2011 | Chevrolet Equinox Cars & Trucks
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
HOW DO YOU CHECK THE OIL LEVEL IN A 1981 HONDA 1100GL
There is a dip stick located on the right side of the engine about 4 inches to the front of the oil fill cap.
Make sure you are on level ground. Unscrew the dip stick and wipe it off. Replace the dip stick and then remove again. Check the oil level and replace. If you need to add oil, remove the filler cap and add oil 1 to 2 ounces at a time. Check the oil dip stick to ensure that your oil level is correct.
NOTE: warm up your bike before performing the above checks.
Regards,
Oz
If you find this helpful, please vote on it. Thank You.
Oct 19, 2010 | 1981 Honda GL 1100 Innerstate Gold Wing
How do I check the transmission fluid in my 2001 cadillac catera
There is no dipstick on the 01 Catera or any Catera for that matter (97 to 01) also same transmission used on 3 series BMWs.
I have 2 - 2001 Cateras....no....dip...stick.
It's a sealed transmission. There are fluid drain plugs, one at side of the tranny and one at the bottom. Jack the car up from the front on a level surface. Place a hose to a funnel and remove the top filler access plug (the side one). Insert the hose here and fill the funnel until fluid leaks out the side hole (make sure you have a catch pan). Then drop the car and let the excess fluid level out from the fill hole. Raise the car again and wipe away the excess fluid and re-install the filler plug.
Jun 19, 2010 | 2001 Cadillac Catera
How many quartz of oil are required in a oil change? what is the proper oil level on the dip stick?
level should be on max if its hot or just below the middle if cold. in order to top up oil we do it in two stages leave cold slowly fill to bottom mark, then wait 5 mins check again should be around middle if not add another 100 mils wait check again. then run car for 10 mins stop engine wipe dip stick clean then check again level should be slighty under top mark this should answer your question
Jun 11, 2010 | 2000 BMW 7 Series
When do I add Oil?
Really you should not have to add oil. But to find out have jeep on level surface and use the dip stick to check. Check with car off, pull dip stick out and wipe off and reinsert, Pull back out and read the stick only add if it is low. Do not over fill.
Sep 23, 2009 | Jeep Cherokee Cars & Trucks
Can you help with a 2006 heritage springer, 88c, I did my own 10,000 mile oil change, crank, and trani. The fluid level in the oil tank is well above the add level. Dealer gave me all required oil and...
Dealer's usually tell you the amount you need if the bike is completely empty. Take a turkey baster and remove some oil, ride the bike and check the oil level again. I have seen to much oil blow the dip stick out and cover everything with oil and I have seen the oil tank split.
Apr 24, 2009 | 2000 Harley Davidson FLSTS Heritage...
Lands Phones Logo
161 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
