Question about Toshiba 50HM66 52" Television
Toshiba 50hm66...Replaced fans.after running for about an hour I hear a sqeaky noise and the piture starts to flicker. Is it the color wheel?I have cleaned the inside but didn;t take color screen off to clean
  • 38 Answers
The color wheel is not behind the screen, it in the optical engine. Most likely thats your issue.
Posted on Jan 01, 2014
SOURCE: 52HM95 - Color Wheel noise - and then it stopped ....
I have the same tv and it is making a loud noise coming from a fan I think, and we already went through 3 bulbs, this tv really sucks I will never buy anything from toshiba again
Posted on Apr 30, 2008
SOURCE: Toshiba 50HM66 problem
Let us say you cannot wait for the lamp to go down in price $25-$50 a piece.
Put it in your driveway and draw a little circle on the center of the screen. Call some kids stand 20 feet away and exercise with a toy gun of their choosing.
When it 's all done, I mean completely obliterated, gone, gone, gone; then drag it to the curb and let it wait with satisfaction for the garbage truck.
That is what you do with **** like this Toshiba, Sony, Panasonic and others create so you can sleep at night with their hands in your pockets.
I just can't believe than I wasted $2,500 on this thing.
It's unbelievable how people stop thinking nowadays. I just bought my first and last big screen.
Posted on Nov 23, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: Screen cleaning solution, smudge underneath display
Try using a blow dryer.
Posted on Dec 06, 2008
SOURCE: How to Access Color Wheel on Toshiba 46HM95
I bought a used 46hm95 but it had a greenish "band" that streched from the upper right corner to the lower left corner. It was only noticeable on a white or light colored background, which is why I overlooked it when I tested out the TV.
I took out the bulb and shined a flashlight into the color wheel. I could see a fingerprint smudge on it. I took off the lower rear plastic panel. the rear is split into two section (the light engine is on the right. You'll have to unscrew a metal guard (three scerws), then disconnect the wires coming from the left section, and then unscrew the plastic guard that protects the lens. Then unscrew the light engine (two screws) and slide it out carefully (you don't have to take it completely out, just far enough to reach the screws to the color wheel covers). There are two covers protecting the color wheel, one plastic and one metal. Unscrew the plastic cover first than the four screws to the metal cover. I left the color wheel in place while I cleaned it with a microfiber cloth. I did pull the glass square in front of the color wheel and wiped that down too.
I put everything back together, and now the picture is perfect.
Things to remember are:
*Keep track of the screws and where they belong, as you remove them so you'll remember where they go when it's time to put things back together.
*Mark the wire connectors from any wire you disconnect in case you forget where they go.
*Be gentle with the color wheel and the glass square because they are fragile.
Hope this helps.
Posted on May 19, 2009
  • 1039 Answers
SOURCE: Toshiba 52HM95 whirring noise
Color wheel. Not replacable on this set. Removing light engine and having rebuilt is only solution. Part no longer available.
Posted on Dec 05, 2009
Is my color wheel need replaced?
the bearings of the color wheel could be worn. the screws hold it in place, & there is a plug-in wire connected to it.
for part# contact: http://support.toshiba.com/
Dec 02, 2014 | Toshiba 50HM66 52" Television
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
I just replaced the lamp in my tv, it will work fine for 10-15 minutes, after that the picture will start to flicker and then just go out completley and th lamp light will blink on the tv set, what could...
My 50HM66 did the same thing. Try putting a fan to the side of the tv so it blows cool air around the back. I also removed lamp and vaccuumed as best I could. I think this is an overheating issue with the tv.
Sep 03, 2010 | Toshiba 50HM66 52" Television
Tv stays on for couple of minutes and then shuts off
Hear any grinding or motor noises,pictures flashes or flickers in black and white?All these cause are the death of a colors wheel.Must replaced the colors wheel.When was the last time,this tv replaced it projection lamp?1 1/2 or 2 years the projection lamp was replaced,tv on and in used like 4 or 5 hours a day.The projection lamp life is over.Require a new projection lamp.
Aug 16, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Cooling fan is loud on initial start up and calms down after a couple hours use. Can I change out the fan and what is the part number on the HL-P4663W?
This tv internal curcuitries and manchanical design have a colors wheel in it.The tv have loud squiling noises,motor noises,black&white or colors flickers and fating.All the effect of the tv colors wheel is dying and spinning off of it motor axis.Cooling fan make noises for a couple hours,calm down,no way.The fan would have stop functioning,way before that.
Jul 21, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Loud humming noise when you power on the toshiba
Good Day,
It sounds like you have Color Wheel That Going bad To verify disconnect cable Color Wheel ***'y. NO noise= bad part.
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 50HM66 52" Television
Make a loud type of humming noise and the color is flickering in and out of color.
IF you are hearing a fan like noise it most likely is the color wheel that this model uses--set was first made in 2004
This model uses two different color wheels--depends on version number you will find on right side of set on a label with the model number.
The color wheel is just what it sounds like--a round plastic wheel with different colored segments that spins at about 12,000 + rpm---a lot of them fail after a few years---usually a fan like noise or grinding noise and sometimes the wheel will shatter and the set will shut down.
Once you ID the version number of your set there are sites on the internet that have video instructions for its replacement--takes less than 1 hour to do this.
If you cannot do it you will pay a fair amount as most shops like to get as much as they can for this easy repair.
LET ME KNOW IF YOU HAVE QUESTIONS
WITH THE FULL MODEL NUMBER AND VERSION NUMBER OF YOUR SET I CAN TELL YOU THE PART NUMBER FOR THE WHEEL.
I am here to help.
REGARDS, SD TECH
Oct 28, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Missing Color.
the color wheel may spin but if you hear noise when it spins it's bad. the jumper is used when replacing one type of color wheel for a nother type. so donot remove jumper unless you've replaced the color wheel and the picture is bad. if the color wheel is good replace the DMD board. if the DMD is not available replace the optical engine.
Jan 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen flicker
When you turn off the set listen carefully... If the noise stops abruptly it's the color wheel, if it winds down a bit after you press power off it's a bad fan..
Bill
Dec 01, 2007 | Samsung HL-S5087W 50" HDTV
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Toshiba 50HM66 52" Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
