Question about Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher
I accidently hit the start button twice and, I guess, set the machine for a delayed start. How do I reset it so that I can start it now? And it's (just now) set to the pots and pans (which is fine) and hot dry (which I don't like) and won't let me change the settings
  • wesrrs May 20, 2009
    Well, I tried that, I also tried cutting the power to the unit for 20-30 minutes hoping it would default and no joy. Finally, several hours later it let me start it. I sure wish I knew this machine better. Thanks!
 To cancel the delay and start the cycle, press START/RESUME.
Posted on May 20, 2009
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
Delay timer is flashing and locked ini that position
did you select delay wash.... it sometimes happen by accident try delay time button to stop delay wash the hit cancel....
Jan 31, 2011 | Kenmore HE3T Washer
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
My dishwasher on/reset button is blinking and I cannot reset it. I accidently pushed this button twice instead of once to start the machine. What can I do?
If there is a Cancel/Drain button press it to cancel all cycles and reset. Otherwise try pressing and holding the ON/RESET button for 15 seconds.
Jul 08, 2009 | Dishwashers
I need to cancel a washing cycle in the middle of the cycle.
usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Hit wrong button
press and hold start/cancel button for 5 seconds and machine should reset
Jul 14, 2008 | Frigidaire Washing Machines
Zwf1430w display problem
My Zanussi ZWG1120m is displaying fault code E60 and E62
I have ben told that the machine needs to be reset. lease can anybody tell me how to reset the machine.
Feb 08, 2008 | Zanussi ZWF1430W Front Load Washer
Can't set time delay.
Would your start button be stuck? check to see if there is something keeping it pressed in? if not your control star button could be shorted...let me know
Aug 23, 2007 | Kenmore 24 in. 16462 / 16464 / 16469...
Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher Logo
623 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
