Question about Sport & Outdoor - Others
I have a Trojan Cardio Coach 460 treadmill . When starting it , she runs at the normal slow rate , but the moment I increase speed , she kicks out to error 1 . I've have turned it off and unplugged it and turned it on a few time but the problem persists , please help if possible .
  • 10865 Answers
SOURCE: Belt just runs at max speed automatically :(
Yes. Replace the speed sensor. In the unlikely event that the problem still is not solved replace the circuit board. J.
Posted on Jul 31, 2010
  • 33 Answers
SOURCE: treadmill not running at all
Your problem might be that a magnet has fallen off. Here's guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
aviral_srms
  • 1216 Answers
SOURCE: treadmill model 909 made by
surely there is some problem in the belt.
One of the ways to extend the life of your treadmill is to keep it clean and dust-free. Dirt and dust build-up, especially between the belt and the deck of your treadmill can cause excessive belt-deck friction. This in turn, can damage your electronics and even your motor.
You can check for excessive belt-deck friction by setting your treadmill around 4 MPH and walking on it. Press the stop button (or pull the emergency stop switch). You should have to take a few steps before the belt stops - if it stops suddenly there is probably a high friction problem.
Excessive belt-deck friction can also cause motor to stall or sound labored so again, keep your belt and deck free from dust and dirct and look out if this is a problem
Posted on Jan 26, 2011
  • 20 Answers
SOURCE: Hi,when i start the treadmill
This error code can mean a few things. Here is a troubleshooting pdf
Posted on Feb 28, 2011
ZJLimited
  • 17970 Answers
SOURCE: Need to reset fitstride T
Error : 4 Power circuit trip.
When happens:
Power circuit broken or motor locked or broken.
Do not use treadmill, call service. Fatal error.
It typically happens during workout (8Km/H to 14Km/H).
During workout (Speed 8Km/H to 14Km/H)? or when they start the treadmill (Start)?
Possible Solutions:
Turn off and on the power.
Push Stop + Slow together , and you are in setup mode.
Push Stop + Fast together in setup mode, and you are in Diagnostic mode.
Using fast, slow key to select "LAST ERROR : "(clear last error) and push Start to clear the
error. Push Stop key , and you are in Stop mode.
Now you are ready to test the treadmill.
Start the treadmill and check the Error message again.
Error 1, Error 2, Error 4, Error 40, Error 41 ?
Check the motor runs or not , when you test it ?
Warning : Do not step on the treadmill, it is very dangerous.
Hope help with this.
Posted on Apr 18, 2011
How do I clear the E 7 message on a Trojan cardio 450 treadmill?
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience.
Mar 05, 2016 | Exercise & Fitness
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Trojan treadmill cardio 450
This is a tricky job. You may have to take off the console to re attatch .
Dec 08, 2013 | Exercise & Fitness
What does Err26 mean?
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
My ProForm 750 only runs at low speed. Varying
If u r seeing the increasing variation takeing effect on the panel but the speed does not increase in real, then there is nothing wrong with the push button for sure.
what it could be is ,
1. Your motor is getting overheat quickly and does not accept the higher speed commands.
2. it could be a belt slip also (do u hear any extra noice / vibration when u increase speed)
3. next time, pls unplugg the unit for atleast 4 hrs and when u start after that increse the speed very next moment and see if it works. if it does increase this way then it is time take look first on the belt ans then check the motor.
Good luck.
Jul 25, 2010 | Proform iLog 750 Treadmill
Describe your Spirit ® XT275 Folding Treadmill Problem - serial number 90488105100032rev-00 I started the treadmill as I normally do by pressing the start button. The belt does not move. I think...
Hi
Thanks for using FixYa. Please read this out:
How to Troubleshoot a Treadmill
If still the issue is not resolved then you can contact local repair center.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 05, 2010 | Spirit ® XT275 Folding Treadmill
Onan 5000 surges
Governor is "hunting. An adjustment should take care of it. nothing more. Take it to camping world and they know what to do.
Sep 15, 2009 | Watts Onan Portable Generator - 5000 ,...
Sport & Outdoor - Others Logo
49 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
