Code on washer machine
My kenmore elite quite pak 2 he3 has been giving a f 06 code it will not drain nor spin what to do??
  • viri_b May 20, 2009
    thanks
  • 975 Answers
Open the washer and look for a small DRAIN MOTOR PUMP , usally this could be clogged with lint and debri . located at the bottom side where the DRAIN HOSE is connected , take it out , clean and remove any debris inside , replace it , and try it again , it should work now . AJ
Posted on May 20, 2009
  • ALBERT GARCIA
    ALBERT GARCIA May 20, 2009
    hope everything works out for you and PLEASE rate this solution , thanks again , AJ
My Kenmore Elite Quiet pak 2 # 11045872402 HE3 washer doesn't go through the complete Cycle it stops when drain and spin,or doesn't Tumble through the cycle? could I have confused it by trying to keep
Spinning is prevented when the cover is open. Possibly a broken "door closed" switch is or its wires are broken. Lift the lid platform and check the switch. May be just debris preventing it from engaging. Remember, the lid and the close switch must be engaged before the control circuit will allow the high speed spin from happening. This is an essential safety feature and should never be circumvented. A high speed drum can literally pull an arm from its socket if caught so make sure it's working properly
Feb 16, 2017 | Kenmore Washing Machines
My kenmore elite quite pak 2, HE3 shows F then H and quits the cycle.
The FH error code mean that no water was detected entering the machine.The things to check are,a pinched or kinked water hose into the washer, the faucets off or if faucets on make sure that something has not restricted the water flow through the hoses..this will be possible espically if they washer is connected using "AQUA FLOW FLOOD STOP" ..the internal flood stopper will cause water flow to be cutoff for no reason. Also check the filter screens on the back of the washer where the fill hoses connect to,for debris in the screens.
If all above checks ok i would suspect the part called the FLOWMETER was defective in the washing machine.
GENE
Aug 28, 2011 | Kenmore 42822 Front Load Washer
Softener does not dispense and we get a code F 30
This error code F30 flashes when the central control unit (CCU) cannot drive the dispenser motor to the proper dispensing position and hence the softener dispensing problem. Disconnect power then remove the top panel and check the dispenser motor assembly for damage or broken parts. You may run a diagnostic test then take a look at the dispenser motor and observe how it behaves. Replace the dispenser motor assembly if damaged.
Click on the link below for the troubleshooting details of this problem and instructions on how to run a diagnostic test.
Troubleshooting Error Code F30 on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
