Question about Logitech USB Desktop Consumer Microphone
My head set has a blue,red,green,white,black and copper wires and want to connect a jack pin with a red,white and copper wire,please help
3 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: I have a Logitech H555 Headset that I need to fit
just plug the jack into the exit of the computer or whatever device u use...and than from the balance turn on just the right channel...tide the ground one ...than try one by one until you figure out which 2 wires makes the right speaker sound...the other 2 will be the left ..
Posted on Oct 26, 2010
linswad
  • 258 Answers
SOURCE: my computer was stollen during a recent break-in.
I don't know what the actual connections are, but no, you can't just connect them all to an RCA plug.
Posted on Apr 23, 2011
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1995
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
Wiring 15312 timer
You are asking about GE 15312 timer.
Open following link for exact single-pole wiring illustrations:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
May 30, 2012 | GE Hardware & Accessories
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
How to connect timer with 4 wires to box with 3 wires
L1 and L2 connect to the black and red. White connects to White. Green connects to the electrical box if it is made of steel and is grounded. Otherwise the green connects to the whites
Dec 30, 2009 | Dryers
Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
May 14, 2009 | Skull Candy Lowrider Headphones
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Need wiring diagrams for headset
I have the circuitry guide for the DSP box. I'm going to consider the top of the board the part with five connections, and the bottom is the part with eight connections.
From left to right on the top, the insulation colors are: red, white, green, black, no insulation.
From the left to right on the bottom, the insulation colors are: white, copper, copper/green, blue/green, red/green, red, copper/blue, green.
May 24, 2007 | Plantronics GameCom Pro 1 Headset
Logitech USB Desktop Consumer Microphone Logo
35 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
