Question about Video Game Consoles & Games
Loud rattling noise
On cold starts loud rattling noise rear head
  • 3 Answers
SOURCE: Loud Rattle and Leaking
If the unit has been working fine for a long time and then you suddenly have this issue, the angle you have the unit set at is probably fine, but you probably have a blockage of dirt/mud/sludge/whatever that is keeping it from draining properly. Here's what you have to do...
For safety... turn the unit OFF and UNPLUG IT.
Open the front gate and remove the air filter. Next, remove the entire front gate from the unit (probably at least one screw to remove first - mine was in the middle, just under wher the bottom of the air filter sits). With the gate removed you should have access to locate your blockage problem.
There is a hole that allows the water to drain from the front of the unit (the part that is inside your house) to the back of the unit (the part that hangs outside your house) and eventually out of a drain hole in the rear. Chances are that this hole is clogged. So, when the water fills up in the front drip tray it has no access to drain to the back. Consequently, the water builds up in the fan area which causes the rattling noise and the water being picked up by the fan and blown out of the vent. If left too long, it will overflow the front drip tray and make a mess in your house.
On my unit, the hole was on the far left side (if your are in your house and facing the AC unit) of the drip tray. You can use a piece of coathanger wire, or some other long thin instrument to push the blockage through to the rear. Once this pathway from the front of the unit to the back of the unit is clear, your problem should be solved. You will probably still get the sound and water sputter out of the front for a little while until the water that is in the fan area drains/dries out, but it should return to normal soon.
It is probably best to actually remove the unit from the window and take the cover off of it and really clean it out, but that is obviously a much more involved task. If you have a hose, that's fine and will help. Water won't hurt the unit - just keep it away from the electronics (the controls/display/cord). You should also be carful not to bend any of the tiny metal fins... that's just as bad as (actually worse than) being blocked by dirt/dust. And obviously, allow the unit to dry before you put the cover back on and put it back in your window and plug it in to run it. If you are willing to put in the extra time and effort, you can do a more thorough cleaning job, which would help to prevent the problem from happening again too soon. There's no way to prevent dirt/dust from building up in the unit. Once water/moisture is added to the mix, you're dealing with mud/sludge, which is going to eventually block that small drain path. The only solution is to clean it out once in a while.
I figured this out the hard way. I took the thing out of the window cleaned it (not as thoroughly as I thought) and put it back in and then did it all again. The third time I actually found the hole that was blocked. If it hadn't been such a pain taking it all apart and cleaning it the first two times I would have laughed at myself for missing it.
Good luck! Hope this helps!
Posted on Jul 27, 2008
SOURCE: engine noise at cold start-up.
Sounds like your oil pump inside the engine is not pumping oil fast enough when you start your vehicle its common problem for mitsubishi motors my car does the same thing.
good luck
Posted on Nov 04, 2008
Jay_from_Ma
  • 99 Answers
SOURCE: noise under hood like rattling sound
Try checking the heat shields on the exhaust pipe up front under the car. Alot of times they will loosen up, and begin to rattle. You can ither remove them, or try to clamp them.
Hope this helps!
Posted on Dec 17, 2008
royhyreno9
  • 50 Answers
SOURCE: LOUD RATTLING NOISE
sounds by your explaination you have a cam shaft problem oil pressure is built through the cam sorry this could be costly have it checked as fast as possable.hope this was helpful
Posted on Jan 17, 2009
  • 38 Answers
SOURCE: Loud rattling grinding noise .....
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Posted on Feb 23, 2009
Trying to find two noises in my 3ltr petrol 407 coupe, cold start rattle and rattle under acceleration especially from a slightly higher gear before kick down occurs. note diagnostics show anything.
Check the exhaust system from front to rear for torn or warn hangers, welds broken on any shields. That is if the noise is a metal noise or rattle. Please describe your noise if this doesn't match.
Feb 05, 2018 | Cars & Trucks
After sitting for a week or so during extremely cold weather, my 1995 Nissan Altima was hard to start. When I did get it started, it was making a loud rattling sound. The noise doesn't go away, but i
rattling sounds like a busted rocker and the valves are loose. when it doesn't start on the first try or so, that sounds like a head gasket. they tend to start better when its hot because it swells some and improves compression. I had a dodge do that but it will only get worse if that's what it is. If you don't get it fixed now you'll eventually warp the heads and be looking at a head job or worse a new car cause its terribly expensive to fix the longer it goes
Feb 20, 2014 | 1995 Nissan Altima
Loud engine noise when cranking kia sedona
oil need to reach upper engine components its wear and such..be looking for loose hardware or anything shaking when starting..
Dec 27, 2013 | 2000 Mazda Protege
Loud rattling noise when cold in reverse or drive
Check engine mount or exhaust mount/damage
Dec 04, 2013 | 2004 Nissan Maxima
2007 Escape Hybrid Was making very loud rattling noises, started to pull over to shoulder of freeway and vehicle started de-accelerating. White smoke billowing out the rear. Pull over safely now and...
that is a service engine light and if you were blowing white smoke sounds like you have a head or head gasket problem as you over heated engine
Aug 17, 2013 | Ford Escape Cars & Trucks
Loud rattle noise started on cold start up but goes away.Now makes noise on/off throttle all the time.Sounds like cat internals or heat shield,inlaws have same car,same noise
Sounds like the Cat could be bad. Get under the vehicle and hit the cat with your hand. If it rattles then you know what your problem is, if it doesnt rattle then start check the belts and tensioners
Jun 22, 2011 | Suzuki XL7 Cars & Trucks
'02 Yamaha XJR1300 Rattle/vibrating noise from bottom of engine
how do you adjust the headlight beam on a xjr1300 naked 2002 bike, is it as simple as undoing the 2 bracket bolts at the sides of the lights and re-setting the lights to a new level ??
currently it seems to be set for riding with a pillion passanger or heavy load at the rear as the lights are set low, no one flashes me even if i ride at night with full beam on !
thanks xjr cambs
Apr 18, 2010 | 2002 Yamaha XJR 1300
Loud rattling / buzzing noise from engine when cold not seconday air pump or air valve as already replaced.Timing belt,water pump and aux pullies all checked and ok.The colder the weather the louder the...
If the rattling changes with the revs of the engine, it might be that the valve compensators are either worn or not getting enough lubrication. 20V engines have quite small oil passages travelling to the head. They tend to clog up with gunk if the oil change is not frequent enough.
Jun 03, 2017 | 2003 Volkswagen Passat
Loud noise
Check your exhaust and rear suspension for something loose or broken. Problem could be the exhaust, a hanger or cracked pipe. In the suspension it could be shocks, worn bushings, track arms etc. When a problem like this happens you have to get under the car and grab and try to move things checking for loosness. In general try to see what is loose enough that a bump causes it to rattle or bang. Other than inspecting the rear area there is no short cut that can be taken to solve the problem. You don't want to just start replacing parts hoping to fix the problem, that can be expxnsive and unnecessary. Good Luck!!!
Oct 13, 2009 | 2004 Mazda 3
Engine noise at cold start-up.
good luck
Nov 04, 2008 | 2002 Mitsubishi Montero
Video Game Consoles & Games Logo
13 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
