Question about Video Game Consoles & Games
Clear the trenches....use/interact button doesn't seem to work to overpower the vc enemy that attacks you as you go under the bridge?
3 Suggested Answers
  • 12 Answers
SOURCE: i cant attack
that sounds like an in game glitch (faulty batch) take back to shop and get refund
Posted on Mar 21, 2010
gopakumarg43
  • 74459 Answers
SOURCE: VC IArt tv doesn't show picture and the power button flashes
There is shorted component/s in the power regulator section to your TV. Check and replace them.
Posted on May 08, 2012
May 07, 2012 | JVC AV-27D302 27" TV
In the Viet Nam section, what is the solution
Just shoot the guy(s) in the bunker, make sure you have enough ammo and the guns you want, relaoad and knock off a few of the soliders in the position to the right of the trench at the bottom, then concentrate on the guys in the trench to the left of that position - then run down to the two barrels, get behind the sandbags and pop up and do the same again but don't sit still for too long. Then wait for your teammate to tip over the first barrel, then run up to the one on the right and hit X to tip it over. Then just work your way around. The tip is to not stay too static for too long, COD single player will just keep respawning the enemy until you die so you need to pop some rounds off, knock them down and work forwards to get behind cover until the next sequence is triggered.
hope this helps
Nov 13, 2010 | Activision Call of Duty Black Ops for Xbox...
How to put in bridge mode
Resetting modem to Factory Defaults
Using the tip of a ballpoint pen or unfolded paperclip, press and hold the Reset button located on the bottom of the router. The pwr LED will blink red once, indicating that the reset has begun. Continue depressing the Reset button for four seconds or until the pwr LED begins to blink alternating red-to-green. Release the Reset button.
Set to bridged mode
Should now be on http:\\10.0.0.138 Click “Login” option. The “Username” is admin and the “Password” is admin. Then click “OK”. Click the “Setup” option and then click the “WAN interface” option. If asked for a Username/Password use admin/admin Click under VC heading the “8/35? option. Click “Next>>” The PPPoE option should be selected and then click “Next>>” again. Under the heading “PPPoE Type” select the “Bridge only” option and then click “Next>>”. Click “Finish”
A reboot is required before the new configuration takes effect. Click the word “reboot”. An additional “Reboot” button will be displayed. Click this “Reboot” button”
Aug 29, 2010 | Siemens SpeedStream 4200 (13A4200001)...
I can't get discussion mode to work on a multipoint conference from my Polycom 8000
Discussion mode will work if your 8000 unit created the bridge call (that is called all other VC units). I think by default the software will allow a bridge call of up to 4 sessions (yourself is included). Also check to see what mode the other VC units are set to.
Jul 14, 2010 | Polycom (VSX 8000/VORTEX EF2280 ) (Bundle)...
I cant attack
Mar 20, 2010 | Microsoft Fable 2 for Xbox 360
How do i defeat the dragon ? at the start of the level and weres the ash tray
Patty and Selma make up the heads of a two headed dragon (real surprise there)
that is reeking havoc on a village. First recruit some villagers with Marge's
mob control. Now switch to Homerball and watch the dragon. It flies and pauses
in between gaps in the bridges that make up part of the upper area. Blast across
the bridge and into the dragon to knock it to the ground. Now switch to Marge
and command the minions to attack. Repeat three times to defeat the dragon
before it destroys too many homes.
The next area is a dungeon. The Moe's will continue to attack until you destroy
the gray brick structure they are spawning from. The coffins house more
potential mob members. Continue forward and grab Marge's police hat near the
bridge. Go up the stairs to the left destroying Moe's and enemy spawn doors.
At the top is a treasure chest and a lever that opens the large door below.
Pass through the door and fight of Otto and his spawn point. Step on the buttons
to enter the overhead camera dungeon crawler portion of the game.
Move up to the large closed off area with the Moes and destroy the wall. Defeat
the Moes and grab the key. Move back around to the yellow wall and it will
disappear. Enter the hole in front of the statue. At the next part of the
dungeon turn left and go to the end of the hall. At the dead end is another
giant key. Head back down and move to the right of the screen toward the
Moes behind a wall. Destroy the wall and retrieve another key. Now move all the
way to the bottom of the area and open the last gold wall to find the exit.
Destruction of both spawn points reveals a couple of pressure plates that opens
the door. Inside are several spawn points and numerous enemies. Try to take out
of the spawn points at first. Once the enemies are gone command 4 mob members
to stand on in each of the claws of the giant dragon. This raises stairs of
gold. Take the stairs on up to the dragon's eyes. Send Maggie inside the right
eye. Press two red buttons to open the dragon's mouth. Enter the mouth and
face three phases against the dragon sisters.
During each phase of the boss fight Homer has to float up and bop Patty and
Selma on the head. Just watch the flight patterns and hover in the area where
it flys the most. In between the 2nd and 3rd wave is an egg wave. Have Homer
run through the eggs to destroy them. If any egg remains it turns into a Moe.
Aug 04, 2009 | EA - Electronic Arts The Simpsons Game
Bridge mode
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Jan 31, 2009 | Westell Wirespeed VersaLink...
Cheat code help
Fate powers:
When you summon an Ent/Balrog in a campaign before an intermission sequence, it will have a its life span reset and will not go down from then.
Change unit stats:
Note: This procedure involves editing a game file; create a backup copy of the file before proceeding. Use a text editor to edit the file in the "alplayers" directory in the game folder. You can change your favorite enemy or ally. For example, the Harassment value can be changed from 0 to 100. Higher values will send more small forces .
One hit kill:
When in a Skirmish level with a river (for example, River Raid), build a Ballista Tower just beside a bridge. When an enemy comes down the bridge, the Ballista Tower will fire a bolt, knocking the enemy back into the river, killing them instantly.
Easy skirmish win:
In skirmish mode. play The Mirkwood Pond map. Have yourself and your opponent on the good side. Have your opponent set to Farmer Maggot (easy). As soon as you begin, have two workers get food and the other get rock. Upgrade your stronghold to level 3. Get Frodo Baggins, and lots of Elven archers. Build the Elven archer and Ranger upgrade building. Upgrade attack and defense as high as possible. Then, upgrade the Elven Cloak. You elves will be invincible. Then, destroy your enemy.
For more of this, download the CHEATBOOK from the website given below:
"http://www.brothersoft.com/cheatbook-database-2008-69389.html"....
If you're an avid gamer and want a few extra weapons or lives to survive until the next level, this freeware cheat database can come to the rescue. Covering more than 14200 Games , this database represents all genres and focuses on recent releases.
On downloading, all you have to do is look into the CHEATBOOK and power your way through the game...
Dec 31, 2008 | Computers & Internet
God of war 2: challenge of the titans mode
CHALLENGE 1 - BLIND FURY
BONUS: SHATTER TWO ENEMIES
For this battle, equip Euryale's head and freeze the Cyclops first (so
he doesn't distract you). Freeze the other two enemies and then shatter
them to get the bonus. Now attack the Cyclops and grab that eye!
NOTE: You can replay this challenge to gain more Cyclops Eyes! Gain
20 eyes to unlock a special costume!
CHALLENGE 2 - DEATH FROM ABOVE
BONUS: KILL 15 ENEMIES IN THE AIR
The best weapon to use is either the Athena Blades or the Spear Of
Destiny. For the spear, use the Triangle + Triangle combo to toss an
enemy into the air and attack them. Try to avoid fighting the bigger
enemies and focus on the smaller ones.
You can only toss the satyrs, soldiers, and gorgons into the air! You
can't fling the berserkers or minotaurs into the air so don't even try!
CHALLENGE 3 - GORGON GRAVEYARD
BONUS: SHATTER 35 ENEMIES
Equip the Barbarian hammer and Euryale's head. Use the Super Gaze
attack (L2 Button + Triangle) on each enemy and then pound on them with
a hard attack with the hammer to shatter them. Use the Fleece to defend
from the other gorgons!
CHALLENGE 4 - PROTECT THE WEAK
BONUS: KEEP TRANSLATOR'S HEALTH ABOVE 50%
This is a very lengthy challenge. The translator sits on a glowing
circle. Every 30-35 seconds, the circle will move to a different area
and you MUST move him towards the circle's new location or he will
start to lose health. As for the enemies, abuse the Amulet and pound
all of them with your hardest combos until the game says you are done.
CHALLENGE 5 - REAP THE REWARDS
BONUS: COLLECT OVER 600 ORBS
CHALLENGE 6 - SURVIVAL OF THE FITTEST
This is also a very lengthy challenge. Your health will continually
decrease throughout the challenge and you gotta keep the dead bodies
flowing (sort of like Shinobi). Survive the onslaught to complete the
challenge!
CHALLENGE 7 - PERFECTION IS DIVINE
Hopefully you've perfected the art of countering with the Fleece
because there's no other way to complete this challenge! Keep your
distance from the petrified minotaur and pound combos onto the other
enemies. You MUST kill the priests or else the challenge won't end!
Once all the other enemies are gone, deal with the minotaur and kill
him with a fatality!
Jul 20, 2008 | Sony God of War 2
Cant connect to "SOUL" adsl
First, just so you know, some devices (modems) just will not work on a provider's (ISP) network.. did you call your Internet Provider and ask it this device is compatible?
When you updated the firmware, did you receive any messages about failures? any messages at all?
Dec 22, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Video Game Consoles & Games Logo
12 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
