Question about NComputing X300 3 User Expansion Kit Graphic Card
How to convert ps2 cunnector to USB connector in ncx 2000-xp
My device is ps2 connector & i have convert to USB Connection because Future mouse & Keybord r USB connector so how to convert Tel me?
    Sergeant:
  • 279 Answers
You can buy devices to convert USB to PS/2 like this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812150091
You might just be better off upgrading to a newer PC if you're able to do so. Good luck!
Posted on Jan 04, 2014
4 Suggested Answers
  • 2678 Answers
SOURCE: how to remote desktop xtenda
A handy little app is Logmein, the free edition is available here
Posted on Nov 03, 2010
  • 86 Answers
SOURCE: GOOD MORNING Sir system please
The update prompt is nothing more than a notification flag, it doesn't really know if there is an update available or not. Having said that, I'd recommend you do the following which should get you all set. Ap Uninstall any current version of vSpace. Reboot. Makesure you have no missing or conflicting device drivers inside of devicemanager. Also, while in Device Manager, navigate to the Ports Section andsee if there is anything listed for Intel Active Management Technology. It will be listed as IAMT or SOL/COM3. If so, right click it and disableit. Then run the NComputing cleanup utility located here:www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP(v4.03.104.1) from here: www.ncomputing.com/download/x300. Unpack the.ZIP file and install. Reboot and register.Do NOT, I repeat, do NOTinstall from the provided CD and upgrade. Simply install straightfrom the download file I provided in the link. Lastly make SURE you REGISTER the CARD and the XD1 boxes.
Posted on Aug 15, 2011
SOURCE: stations stopped it says internal
Please add serial numbers and codes located on terminals in order to solve the problem.
Posted on Feb 08, 2012
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
Dell Vostro with XP - cursor is running rogue and endlessly going backward.
This "can" be malware, but is most likely your pointer device going wonky. First unplug the mouse, trackball, or whatever it is you are using for a mouse. If you are still using an old PS2 connection (round plug), consider getting a USB mouse to replace it.
Plug your mouse back in and see if it solves the problem.
Try a new mouse.
If it's not the mouse (you just said the cursor is moving) it could be that the left arrow on your keyboard is stuck. In that case, rake your keyboard, tap ******* the arrow keys, turn over the keyboard and shake out any large Cheeto crumbs, use compressed air (if possible) to blow the dust out.
Unplug your keyboard from the computer and plug it back in. If you are still using the old PS2 keyboard (round plug), consider getting a USB keyboard to replace it. *** warning
*** warning, do NOT throw out the old PS2 plug keyboard if you replace it. You may need it to get into the BIOS some time in the future if the electronics don't recognize a USB keyboard on boot.
Feb 07, 2018 | Dell Vostro 1520 Notebook
How do i connect a computer mouse to a samsung notebook
what's the mouse connector? is it PS2 (a round connector with pins on it)? or USB?
if it's USB,you can directly connect it to your notebook,if it's PS2,then you need to use a PS2-USB converter,it's cheap
Aug 23, 2012 | Samsung N150 Notebook
Mouse in laptop is net move
if the system isn't frozen, there might be something wrong with the connection, mouse driver, the mouse or your mainboard. So you can check them one by one. If you are using USB mouse and it works on another computer, try another USB port on this computer or open control panel and device manager and update the driver of the mouse or the USB device for your mouse (right click on it and choose update driver then choose the driver from windows system32 drivers folder for usb(something named as usbstor.sys or something) or the one on the CD come with the mouse) or you can try USB/PS2 converter if there is a PS2 mouse port on your laptop and also you can try wireless mouses for options if you do have one.
Sep 09, 2010 | Computers & Internet
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
How do i connect my PS2 with my PC
on the back of your computer box, you will (probably) find 2 ports that look like this. the PS2 mouse will be plugged into the green colored port. NOTE: PS2 mice (and keyboards) will only fit into the port ONE DIRECTION, so don't force it! make sure to line it up
once plugged in, you will need to reboot your computer, as PS2 can only be recognized while the computer is starting up.
one final note: some of the newest computers DO NOT have PS2 ports. if this is true of your computer, you will need to get a new mouse, or an adapter, like the one shown below:b6b70e7.jpg
Aug 27, 2009 | KEIO PS2 Optical Scroll Mouse
I can't install vista any mouse or keyboard detected
Often times this happens when using a USB keyboard / Mouse.
Or when using a USB keyboard through a PS/2 Converter.
Try using a PS/2 Keyboard if available
(Small Round connector with a small amount of pins, similar to a S-Video connector.)
Also. Access your BIOS settings and assure that you have Legacy USB keyboard support.
Depending on your computer the BIOS / Setup Menu / Options Menu/ Etc. can be accessed by pressing the following key during boot:
F1
F2
ESC
DEL
F12
Let us know your setup(KB and Mouse Port type), and if you have any other issues.
Good luck
Apr 14, 2009 | ASUS P5V800-MX Motherboard
NComputing X300 3 User Expansion Kit Graphic Card Logo
98 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
