Question about Ricoh Aficio 2035 Copier
NASHUA AFICIO AF 1232C. THE MACHINE IS GIVING US THE ERROR CODE WHICH IS SC570
FUNCTIONA PROBLEM WITH THE COPIER. PLEASE CALL SERVICE AND REPORT THE SERVICE CODE. SC570. SERIAL NO. OF MACH J2656220028
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Try entering service mdoe - SP5810 to clear error
Posted on Mar 03, 2014
4 Suggested Answers
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
  • 2072 Answers
SOURCE: what is error code sc548
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Posted on Jul 19, 2010
HOW DO YOU GO TO SERVICE MODE ON A RICOH AFICIO 3224.I JUST FILLED THE OIL BUT STILL GETTING SAME ERROR SC570.DOES THE OTHER PIPE ON THE OIL TANK CONNECT ANYWHERE BECAUSE IT IS JUST HANGING THERE.
Hello Peter,
Once the device has been neglected for oil long enough you will get this error code. Usually people don't wait until the code occurs. You WILL INDEED need to go into service mode. To do this,you will need to follow a fluid 3 step process. First locate the "CLEAR MODES" key located obove the 9 key pad. It is yellow. Now locate the red STOP button located below the 9 key pad.Ok, to enter service mode you will need to press "Clear /Modes"and release,then press the numbers "1,0,7" in a 3 step sequence and release, then press the red STOP button and HOLD it down till the device beeps. The screen will change and say service mode. Press "COPIER". The screen will change again. Using the keypad press 5,8,1,0 and then press the pound sign {#}. You will be prompted/asked to EXECUTE. Press EXECUTE. Now unplug the device while in service mode after the execution of the 5810. Wait a sec, plug her up, and you are done. Have a good day and let fixya know I helped. :-) SPINAL
Jul 23, 2011 | Ricoh Aficio 1232C Color Copier
I have a ricoh 1232C multifunction and it has just stopped working and gives an error code sc440 " Functional Problem with the copier "
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
Oct 18, 2010 | Ricoh Aficio 1232C Color Copier
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
ERROR SC 570 RICOH AFICIO 1232C HOW CAN I FIX
The machine has no fuser oil.
Fill the little tank at the back side of the machine. If the tank is full, check the tubes, oil pump, and oil sensor.
Reboot the machine to clear the SC.
The problem will be solved
Aug 10, 2010 | Ricoh Aficio 1232C Color Copier
I have a Nashua Aficio 1013, it gives me a SC549 error report and it doesn't perform any of its fuctions. how can i solve this problem?
This is a fusing temp problem. Try the following to reset. function clear(yellow button) 107 hold down Clear button(red button)Machine will enter SP mode. Go to menu 7 (Data log) go to 807 ( SC/jam reset). Input 1 for yes. hold down the original type button (the button where you select Foto/text) then press #. Machine will reset and show action complete. Turn machine off and back on. If the problem is still there you will have to check the thermoster and might have to be replaced. But normaly this will do the trick.
Apr 26, 2010 | Ricoh Aficio 1013F Copier
ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Jan 14, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
Dec 17, 2008 | Office Equipment & Supplies
Ricoh Aficio 2035 Copier Logo
102 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
