Question about Maytag Neptune MDE5500AY Electric Dryer
Heating element only turns red when dryer door is open
Admiral model#ADE7000Ayw I noticed that the clothes were taking longer and longer to dry. I had both thermostats replaced-not any difference. I ran it with the top up so I could see the element and noticed that when I started it with the door open all the way, the element would get red hot, but when I slowly moved the door to about 3 inches of being closed, the element would shut off to just warm.I also think that the element has a break in it caus when it does light, the upper coil does not get red with the rest.
  • lizard_king0 May 20, 2009
    Thanks for your feedback
    Sergeant:
    Champion:
  • 219 Answers
You are correct you do have a dead short on the element.You need to replace the element.Hope i fixya :)
Posted on May 20, 2009
  • 56 Answers
A half heat link connection on element may be burnt off which is worth checking
Posted on May 27, 2009
My Admiral Heavy duty dryer is taking longer and longer to get clothes dry. Usually two cycles whereas, it used to take one. Help!
clean the lint trap really well and also check where it dumps the hot air outdoors . tat sometimes clogs with lint also .if this does not fix then replace the heating element
Aug 09, 2015 | Maytag Dryers
Admiral dryer wont dry clothes
one of several things can cause this . contacts in the timer , heating element ,door switch to name a few .plugged lint filter also can cause poor drying as it slows the air flow .when all else fails call a service tech
Mar 13, 2015 | Admiral Dryers
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
My dryer is a whirlpool estate. i have had it for about 2 years. I have noticed lately that it is taking longer about 40 minutes longer and then some depending on the load. to dry my clothes. i have...
make sure all vent openings are clean lint trap is clean,and the door is opening properly on the out side when dryer is on, if you have done all that check the thermostats on the heating element housing it may be bad, i hope i was able to help.
Dec 28, 2009 | Washing Machines
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer does not dry as fast as it used too. Takes two cycles to dry a big load. Filters and exhaust are clear, and blower is still blowing. Looking in heat element, seems like botton 1/3 of coils don't turn...
Then part of the heating element is most likely not working because it is burned out or the high heat setting on the control no longer functions. Let me know the model number located most times inside the door on the wall of the door opening. That way I can Help you better, Thanks, Sea Breeze
Jul 13, 2009 | Whirlpool Dryers
Dryer heats but takes a long time to dry
Hello Jeff,
You may have a bad overtemp switch that is disabling the dryer heating element ( normally as a safety mechanism to keep it from over-heating and/or causing a fire) from staying on. Many ( but not all) are of the auto reset type and open the circuit if they are sensing high temperatures. When they sense this over temp condition , they open and disable the heater element from being energized. Once the temp drops to less than their limit, they reset and allow the heater to switch on. That would be one consideration to investigate. If you can gain acess to te back of the dryer, you can bypass these switches by shortng the wire leads together.. Do this as a diagnostic only.. and DO NOT leave them that way.. you risk having a fire if you do.. also.. make sure you remove or disable power to your dryer when you are checking this out. If the dryer heater remains on after you short the temp switch leads together, then you wil have proven that the temp switch is the problem and it shoul dbe replaced..Hope this helps you...
Sep 18, 2008 | Dryers
How to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
May 21, 2008 | Dryers
Dryer leaking water
it sounds to me like the heating element that heats up to dry the clothes has gone faulty or tripped out. Cant really tell from here.. when you open the drier is there a good level of heat ? If not, its the heating element section at fault.
Mar 17, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
339 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
