Question about HTC Touch2 T3333 (UnlockedNo Contract) PDA Phone Silver Cell Phone
Code secret - HTC Touch2 T3333 (UnlockedNo Contract) PDA Phone Silver Cell Phone
Turtle knock seceret code
Looks like it's very secret
4 Answers What is the secret code for literacy planet turtle knock ...
www.fixya.com/support/t24424275-secret_code_literacy_planet_turtle
  1. Cached
  2. Similar
May 15, 2014 - Ammoforall. SOLVED: What are cheat codes for turtle knock on ... 10 answers Jul. 20, 2017 1 Answer What is the secret code for literacy planet ... 10 answers Mar. 1, 2017 What is the secret code of turtle knock? 11 answers Nov. 24, 2016 Literacy planet cheat codes turtle knock 9 answers Sep. 28, 2015 More results from www.fixya.com
What are some cheat codes for Turtle Knock on Literacy Planet ...
answers.wikia.com/.../What_are_some_cheat_codes_for_Turtle_Knock_on_Literacy_...
  1. Cached
  2. Similar
... When, Why, How, etc..." in your question. Nothing to ask? Click here for a random, un-answered question. in: Literacy Planet, Cheat codes, Secret codes ...
What is a secret code in literacy planet on turtle knock? ' Wikianswers ...
answers.wikia.com/wiki/What_is_a_secret_code_in_literacy_planet_on_turtle_knock
  1. Cached
neverrunoutofshots: unlimited shots (MAY NOT WORK)
Jun 01, 2018 | Audio Players & Recorders
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
Leapsterworld secret codes
looking for creature create to enter secret code
Jul 26, 2014 | Leapster Junie B Jones Top Secret Personal...
Forgot secret code to access restart
CLEARING THE SECRET NUMBER
If you forget the secret number, clear the secret number using the following procedure.
1 Select an item from the list below to display the secret number input screen. (For operating the on-screen
display menu, see page 17.)
• "EZ Setup", "CH Setup", "Parental CTRL" or "Reset" on the Setup menu.
• "Color System" on the Option menu.
• "Software Update" on the Digital Setup menu.
2 Press and hold both CHr and VOLk on the TV simultaneously until the message appears on the screen.
Jan 27, 2014 | Sharp LC52SB57UN LCD TV
Je veux le code de formatage de lg kc910
LG Secret Unlock code LG Cell Phones Blog
Here is a method to unlock the LG Secret easily and safely. LG Phone Problem and solution
1. insert original sim card and turn your LG Secret on. LG-Secret info
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
4. Enter your unlock code and press ok
5. The LG Secret will then reboot and the unlock is complete.
Oct 05, 2012 | LG KC910 Renoir Cell Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
Increasing volume in samsung s3310i (secret codes)????
sorry there is no secret code for same
Dec 18, 2010 | Cell Phones
Mujhe n 72 k pure secret code chahiye please koi meri help kare meri email id hai. afzal.niky@yahoo.in
secret code is very risky.to get secret code you have to paid.i have all secret code of nokia also have the unclok code.
Mar 21, 2009 | Nokia N72 Cellular Phone
HTC Touch2 T3333 (UnlockedNo Contract) PDA Phone  Silver Cell Phone Logo
16 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
