Sansui por1004ip portable radio
Can you please tell me where is the power on/off switch on this product
Replacing battery
What battery number or voltage/size?
Apr 16, 2014 | Sansui Audio Players & Recorders
Sansui portable tv capacitor
There are so many capacitors of different capacitance, and with different voltage levels. About which capacitor you are asking about? If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Sansui Televison & Video
Do I connect my Cassette deck player to the "Switched" or "Unswitched" plug at back of Radio? please help. Radio is a Sansui Model 210SS and tapedeck a Pioneer model CT-F2121.
It can be plugged into either one. Just remember that the deck will only power up with the radio on if it is plugged into the switched jack.
Aug 12, 2013 | Audio Players & Recorders
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Hold switch is on?
You should just need to push the power switch down from the hold position. When it is pushed all the way up it is in hold mode. Sometimes that switch can break and affect the functionality of the Stiletto. If it is broken, you can contact a repair guy via email at sales@tss-radio.com or you can buy a replacement at http://www.tss-radio.com/products/sirius-stiletto-2-live-portable-receiver-sl2pk1
Jun 08, 2012 | Sirius Stiletto 2 Portable Satellite Radio...
Is there a free website for sansui tv's such as model # tvm2515?
none that I know of. What seems to be the problem? Best Buy carries this model and would be a good place to start to resolve most of your questions unless they are as usual clueless about their products if you didn't by it from them
Stu
Mar 23, 2012 | Televison & Video
Having a whining noise in my speakers in an 07 suburban, stereo does not have to be on and it will even make the noise when you use a turn signal. And it only makes the noise on the passengers side...
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
NFORMATION Bulletin No.: 06-08-44-015B
Date: May 12, 2009
Subject: Information on Eliminating Noise in Audio System When Using Portable Playback Device
Models:
2010 and Prior GM Passenger Cars and Trucks (Including Saturn)
2010 and Prior HUMMER H2, H3
2005-2009 Saab 9-7X Supercede:This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 06-08-44-015A (Section 08 - Body and Accessories). Some portable audio equipment may be susceptible to certain types of electronic noise present in the vehicle's 12V power outlet.
Here are two ways to eliminate this type of interference:
- If the audio device is capable of being self-powered (battery), use it that way instead of plugging it into the vehicle's power outlet. - Have the customer purchase a Ground Loop Isolator, such as *Radio Shack Catalog #270-054. This device plugs in between the radio and the customer's audio device. It is packed with one included Y-Adapter. If purchasing the *Radio Shack product, you will require an additional Y-Adapter (Catalog #274-369). This device should be installed between the audio player and the AUX input of the vehicle radio. These catalog numbers are stocked nationally at *Radio Shack Retail Stores in the U.S. and are currently available. Other similar products are available through other electronics or car stereo retailers defined as Ground Loop Isolators. Parts Information
Parts are currently available nationally in the U.S. through *Radio Shack retail locations or through the mail at Radio Shack direct ordering 1-800-843-7422. In Canada, parts are available nationally through *The Source By Circuit City retail locations or at www.thesourcecc.com.
148924792
*We believe these sources and their products to be reliable. There may be additional manufacturers of such products/materials. General Motors does not endorse, indicate any preference for or assume any responsibility for the products or material from these firms or for any such items that may be available from other sources.
Jan 02, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Sansui 3618 tv
that seems to be a 3.15amp fuse. if it blolws then there is a short circuit
Mar 03, 2008 | Televison & Video
20 people viewed this question
 Grubhead
Grubhead
