Question about Home Security
Panacom intercom The transformer for my panacom is faulty & I'm having trouble sourcing one with the correct L shaped plug that goes into the unit. Where could I buy one? Thanking you in anticipation. Regards Trevor
otacon
  • 1944 Answers
SOURCE: lost my cd that came with k800i and want to connect to computer
You can download the software from Sony Ericsson.
http://www.sonyericsson.com/cws/support/products/softwaredownloads/k800i?cc=gb&lc=en
Posted on Feb 25, 2008
Teckies
  • 226 Answers
SOURCE: DONT UNDERSTAND GADET
gadjet?
Posted on Jun 15, 2008
  • 567 Answers
SOURCE: Hi I have a GOODMANS GCDR
go to the goodmans net site and you should be able to download the manual from there for free
Posted on Oct 20, 2010
rommelalilin
  • 2178 Answers
SOURCE: Good day Sir/Lady I have purchased
If this has an analog tuner, you will not be able to receive the digital broadcast stations - you will have to get a digital convert box. The analog broadcast are no longer available. You will not get any stations. The digital boxes have remote controls - thus you won't need your current remote control.
Posted on Dec 22, 2010
SOURCE: Same error #45 on V610
I AM FROM BANGALORE, I GOT MY KODAK V610 REPAIRED AT MATA ELECTRONICS, NO86, 1ST FLOOR, NEAR TOWN HALL.VERY GOOD SERVICE, THANXTO MR VIJAY. CONTACT HIM AT 9035871324/ 08022130711
Posted on Jul 29, 2011
Want to use removed 95 Nissan Maxima's radio unit and 2 rear speakers as a stand-alone system at home. How to apply +12 V to the radio unit and speakers? Which wires (out of plenty of them exposed) sh
red is normally power in and black is normally earth wire. Get a 12 volt dc transformer that plugs into the power outlet and get the plug jack socket from a electronic shop and solder the wires correctly (red to centre pole ) and it should work . You will need a high wattage transformer for this.
Nov 12, 2013 | 1995 Nissan Maxima
I have a commax intercom (dp - 2hp model). There are two wires connected from the bell outside to the connectors 1 & 2 on the unit inside and the bell is working. There are another two wires connected to...
you just said where everything goes, so what's the question?
connector 5 goes to your gat actuator, 6 is power for the unit, obviously there will be 2 wires for each for a complete circuit.
Oct 04, 2013 | Radio Communications
My Orbit 57899 is saying no ac but the outlet to where this goes is working fine
I believe that you plug a transformer into the outlet. If this transformer is not working, no power goes to the timer. Remove the battery and if the timer display goes out (and it may take some time, possibly hours) the transformer is in need of replacement. They are available at sprinkler suppliers and maybe even a local hardware.
Gary
Jul 03, 2011 | Orbit Sprinkler System Power Source...
Keep burning power conversion plug on PC board I am running unit at 230 volts I have change transformer also
You should first start with converting the unit to run on 115 VAC if you can. We had a unit that went thru three ignitors, 2 selector boards, two main boards and a transformer in one summer in part because the electronics in that model are sensitive to spikes and spikes on a 230 circuit are worse than the same spikes would be wired for 115. Jandy was the source for that recommendation, not us.
Anyway, consider changing the line voltage and thoroughly inspect your main board to be certain it is not damaged. Assuming the main PCB is ok your best bet with a new part should be low voltage. Since we converted the unit we were working on it has been trouble-free.
John
Oct 26, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
On power up my kurzweil micro piano has no audio out and lwhen plug into amp has a hum.
If the unit uses a wall transformer power supply, verify that it is correct and in good shape. If it is DC and half of the rectifier is gone, then result would be what you are observing.
May 21, 2010 | Yamaha Electric Guitar
When I press the power button to turn the unit on,
Check your cord first, make sure it's in good shape. Sometimes the main transformer goes out, and you can use a DC adapter to bypass the 120 V source. Could be a fuse, or something else in the power supply inside the unit.
Mar 13, 2010 | Durabrand CD Boombox, Pink Boombox
It has an hourglass shape when first turned on but
Your TV set has trouble in its "pincushion correction" circuitry, which corrects distortion so the picture is straight on the screen. Unfortunately, it's not possible to pin the trouble down to a specific part without having the set for troubleshooting. Since the trouble clears up after the set's on for a time, it's probably due to a faulty capacitor or intermittent solder connections. Because of the troubleshooting skills and tools needed, you should let a professional service shop handle the repair. This kind of problem is relatively inexpensive to repair (at least parts-wise; I've been out of the repair business for a while now, and have no idea what kind of labor prices shops are charging) and would not cost nearly as much as a replacement TV.
Sep 24, 2009 | Panasonic CT-35XF53 35" TV
SONY VAIO IS NOT CHARGING BATTERY
I hate to ask this, but I have to..... Is there power at the wall outlet? Okay, now that the stupid question is out of the way (you'd be surprised how many service visits I've made for this)
make sure the AC cord between the wall and the transformer is in good shape and securely connected to the transformer. If you have a voltmeter, measure the voltage at the transformer end of the AC cable and make sure you have AC voltage there
If there is a light on your power adapter transformer, see it it is on.
If there is a light, and it's not on, but you have voltage at the AC cable, then the transformer is not working and must be replaced.
If there is no light or the light is on, check the DC voltage at the power connector that plugs into the laptop. The correct voltage should be written on the transformer casing.
If you have voltage there, then your battery may be faulty. Otherwise there is a problem with the circuit between the adapter inlet on the laptop and the battery.
Sep 05, 2008 | Sony Computers & Internet
Home Security Logo
192 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
