Question about Car Audio & Video
Amp keeps blowing internal fuses on a memphis 16-mcd1000
When I turn my bass up amp gets hot after about 5 mins and blows the fuses on the inside of the amp
    New Friend:
Got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
Posted on Dec 31, 2013
4 Suggested Answers
Duncan
  • 218 Answers
SOURCE: My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Posted on Feb 23, 2007
sparky1500
  • 1066 Answers
SOURCE: Ashdown Perfect 10 Bass Combo keep blowng 2 man fuses
What main fuses? Fuses in the car electrical system? If so, your amp is too powerful to run through the cars electrical system, you should get a heavy guage wore ran straight from the battery, with its own dedicated fuse placed in-line, ad close to the battery as possible. Wait, is this a bass guitar combo??? Open it up, if there's wax coming from the power supply, thats prolly the culprit. Check for any obviously blown resistors or any short circuits. But most likely, its not gonna be user-servicable.
Posted on Mar 01, 2008
jerryg50
  • 1689 Answers
SOURCE: AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Posted on Apr 25, 2008
I have a Memphis a.m. and was working fine one day the next day it was blown fuses and not working
Fuses blow due to an overload of caused by bad speakers or wring. However the main cause will be a shorted part in the main amp section. Maybe the result of the bad speakers or wires.
Mar 25, 2018 | Memphis Audio 16-XO3 - Memphis 3-Way...
NO turn signal or neutral light, no speedometer or horn working. Changed 10 amp fuses but they keep blowing?
10 amp fuse is small a few things that you can do. go to a 15 and turn every thing on snd see if it blows and how long. if it don't blow in 5 mins. your good if it does blow then you have a wire problem. if so. unplug every thing that has to do with that fuse. and plug 1 in at a time UNTIL the fuse blows. good luck.
May 03, 2016 | 1999 Yamaha V Star 1100 Custom
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
Have a hartke lh1000 head . played about 5 total hours then blew the fuse. is this something i shoud be worried about?
If the fuse is correct ( check manual) it shouldn't blow under normal operation. Once in while a fuse will break internally and thus blow the fuse. look close at the blown fuse If it is a "violent" blow (totally black inside) then you have an overload condition. I would use an ohm meter to check the connection to the speakers. Usually it should be between 8 ohms and 4 ohms if the number is lower than 4 ohms your speakers or wiring are putting to much of a load on the amp. If the fuse was not a "violent" blown fuse then replace with a new fuse of the exact proper value. many amps use an MDL fuse that is a slow blow fuse and has much different in circuit function than a ACG fuse so use only the exact proper furse that the manufacture recomends. If the load (speaker and wiring) is correct and the fuse is correct and still blows then you have a component problem and the amp will need repair
Jan 19, 2012 | Hartke Lh1000 Bass Amp Head 1100 Watts...
My blowermotor fuses keep blowing withih 5 min. of putting them in. We have changed the blowermotor and the resister. What else can it be
check the switch if it's not making a good conection it will cause a high amp draw and blow the fuse after it gets hot
Nov 20, 2009 | 2002 Ford Explorer
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Jerry G.
Apr 25, 2008 | Car Audio & Video
Feb 23, 2007 | Hifonics BXI 1606D Car Audio Amplifier
Car Audio & Video Logo
194 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
