Question about Siemens Cell Phones
Y300c No network hardware solution - Siemens Cell Phones
I know my huawei y300c imei 869046013276947 for
To remove sim network unlock pin from your Huawei y300, use unlock code . You can get it from any of the online vendors like WickedUnlock.com to unlock it .
Nov 12, 2014 | Cell Phones
T23 duo light problem
y300c
imei is 869046011175794
sim unlock code?
Sep 07, 2013 | Cell Phones
Huaweiy300c unlock pin
I need to unlock coad my phone Y300c imei 869046018100670 my gmil linaung211176
Sep 01, 2013 | Huawei Cell Phones
I keep getting kicked off of live. its saying its not responding to icmp responses.
I am guessing that you were able to connect before this problem happened, so you have to restart your network hardware. To do this:
  1. Turn off your Xbox 360 console and network hardware (for example, your modem and router).
  2. Wait 30 seconds.
  3. Turn on your modem and wait for it to come back online (approximately one minute).
  4. Turn on the next piece of hardware (for example, a router), and wait another minute.
  5. Repeat step 4 for every additional piece of network hardware.
  6. Turn on your console, go to My Xbox, and then select System Settings.
  7. Select Network Settings.
  8. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  9. Select Test Xbox LIVE Connection.
May 31, 2011 | Video Game Consoles & Games
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
When I reload my F5 5100 I get the following message "hard error: sector 1019072 status 51 error 14: bad format"
Hello my friend, it refers to your hardware components. The error is on your hardware system it causes either the hardware itself where it has a error in the area of SECTOR 1019072 where its status is bad format or its the format of one of your system inside your hardware.
Thanks
Jul 30, 2009 | F5 Networking (f5-big-5110) 24x10/100 Mbps...
Fiber-optic networking
Apply load balancing of the NIC interface, else put in a switch to interconnect all the computers. That should give equal speeds to all the PC's.....sodeep
Apr 06, 2009 | Computers & Internet
Remote Network Question
some for your hardware need software, kindly check with hardware properties,configuration
Mycomputer -----right click-----properties-----hardware----check all the drives are compactable , without any question mark,
May 15, 2008 | 2wire 1000-200004-000 Network Adapter
About laptop ethernet...
First figure out whether your hardware is ok and driver is installed properly. In Windows XP, click Start , right-click My Computer , and select Properties .
  1. In Windows 98 and Me, right-click My Computer , and select Properties .
  2. In Windows XP, click the Hardware tab, and then the Device Manager button. In Windows 98 and Me, click the Device Manager tab.
  3. If the Network adapters category is present with a (+) sign , then skip to Step 6. If Network Adapters has a (-) sign , continue to Step 5. Disregard adapters that do not reference an Ethernet Adapter .
  4. If a network adapter is not listed inside, do one of the following items based on the condition of the networking hardware:
    • Networking hardware is not installed. Install a new network card (desktop computer) or a new network PCMCIA card (notebook computer) per the card manufacturers' suggestions. This does not apply to on-board networking hardware.
    • The network card is not seated fully into its socket. For Desktops, remove the side-case, reseat the network card, and replace side case. For notebook computers, remove and reseat the network PCMCIA card. This does not apply to on-board networking hardware.
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play network card is probably a better option.
    • For desktop PCs with on-board networking hardware, reset the BIOS:
      1. Restart the PC.
      2. Press F1 repeatedly when the first screens appear.
      3. Press F5 and Enter to reset the BIOS to default settings.
      4. Press F10 and Enter to save the settings and exit BIOS setup .
      5. Restart the PC.
      6. Check Device Manager again for the presence of the Networks adapters category. If the network adapter name is still missing, the on-board network adapter may be damaged. The motherboard should be replaced, or a PCI network adapter should be installed.
  5. If the network adapter is listed, but has a yellow exclamation mark over its icon c00060708.jpg , do one of the following:
    • Software drivers and supportive files may be missing or corrupted. Remove the device from Device Manager and reinstall the software by restarting the computer. See Step 5: Reinstalling network adapter software drivers .
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play card is probably a better option.
  6. If the network adapter listed has a green adapter icon c00060709.jpg , the networking adapter is probably functioning correctly. If the PC still cannot connect to the Internet, make sure to complete the following steps before continuing:
    • The cable or DSL hardware may have stopped responding. Reset the cable or DSL hardware using the manufacturer suggestions.
    • There still may be a connection problem. Recheck the cable connections and replace any cables that have been pinched or that you suspect are bad.
    • The Internet Service may be down at your provider. Most Service Providers have a telephone support number. Call the ISP support number. If an outage is occurring, an automated response about system wide service outages will probably play. In this case wait until the service comes back.
    If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Thanks
Iqbal
Mar 16, 2008 | HP Pavilion ze2000 Notebook
Cell Phones Logo
105 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
