Question about Polaroid FLM-3732 Television
No signal flm3732
Dish tv no signal
I have no signal with I turn on my tv, I have dish. It is on channel 3.
tried to reset first the dish then check if it can get signal now, if still no signal receive you can hooked up the dish to the other tv just to ensure if the cause will be in the tv. just let me know if it works, if the same problem the cause will be the dish has a problem.
Nov 08, 2012 | Vizio 42 in. LCD TV
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
POLAROID FLM3732
There is an easy fix for this. You can go to youtube and look up flm3732 repair or just visit my channel my sn is Raider2845. It only cost me a few dollars to fix the tv. Its very easy and just about anyone can do this.
Mar 14, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Can't get picture
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Shuttle83
Jul 23, 2008 | SVA-USA SVA HD4208TIIIBU 42" Plasma...
Sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Jun 20, 2008 | Televison & Video
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
