Question about Smeg 24 in. DWI612 Built-in Dishwasher
Blocked pump in smeg dishwasher - Smeg 24 in. DWI612 Built-in Dishwasher
Smeg dishwasher problems
Check the screen, which is under the bottom wash bar. You need to pull out and clean and then see if it will drain. Also listen to make sure the drain motor is running, it also could go bad on you.
Aug 25, 2014 | Smeg Dishwashers
I cleaned out the filter on my Smeg integrated dishwasher, model D16012, yesterday then started a fully loaded cycle. The items were all clean when I unloaded but some water remained in the bottom of the...
It may be possible that something fell out of the filter and into the drain pump. The machine will do a short drain cycle at the start of a program and if it is jammed or blocked, this will cause this problem.
Jul 02, 2014 | Smeg Dishwashers
E5 smeg dishwasher
Water inlet solenoid valve faulty. Check this is voltage to valve when water should be flowing. Replace valve if there is voltage present.
Jun 04, 2014 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Dishwasher cavitates. I have a Smeg DI612CA9
Does the drain hose loop up to the top of the unit before going to the sink drain? If it goes down first it may be siphoning or draining by gravity.
Aug 08, 2013 | Smeg Dishwashers
Dishwasher will not drain
First check for blockage then listen for humming sound when its suppose to be emptying, the drain pump may be blocked or may have died.
Jul 02, 2010 | Smeg CSU2001 Built-in Dishwasher
Supply of WHITE pump unit.
You could purchase it from :-
http://www.espares.co.uk/part/dishwashers/smeg/p/1083/1213/0/0/969614/dishwasher-motor-housing-.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Dishwashers
Smeg dishwasher DWD612SS Fault
Chec k if orifices in the spray arms are clogged, if lines are free and it is not sprayiong water, then yopu may need to check water lines and to replace the impeller pump.
Jan 25, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Dishwasher not working
try this first is there still water in dishwasher if so your water pump is blocked or failed.
second check your tap connection has it got a flood lock device fitted to hose if so will have to replace hose.if none of these help you may need to replace pcb in extreme cases.
hope this helps.
Jan 07, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Smeg dishwasher EN50242
have a Smeg STX-45 dishwasher. After washing the utensils, machine is not able to drain the water. Can you please tell me what could be the problem. Is there any switch I need to press for the same or something else. I have used the machine for the first time.
Oct 12, 2007 | Dishwashers
Smeg 24 in. DWI612 Built-in Dishwasher Logo
24 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
