Sansui cd-210 How to set wiewing angle on LCD display
Philips remote control not working
have the remote tested, any repair shop can do this and usually for free.
If remote is good the receiver in the set is likely bad.
Nov 27, 2012 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Sansui video & audio setting disturbed. Need service menu code, sansui 3281-xwm India
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 07, 2012 | Sansui HDLCD3210 32 in. LCD TV
Picture to big
Try going into picture setting and reduce the zoom angle or if it's whilst you are watching Sky TV go into System Settings, Picture Settings and change the Aspect Ratio (ie. From 4:3 to 16:9 or visa versa)
Gadget
Feb 21, 2012 | Sansui 19 in. LCD TV
I have hmdi cords and I am trying to get the tv to turn to 1080I how do I do that
This Sansui HDLCD-1900 can only do 720p MAX. The source will determine the display resolution, you do not set it at the TV, just like you do not set the PC monitor resolution at the monitor, it is done at the PC. http://reviews.cnet.com/flat-panel-tvs/sansui-hdlcd-1900/4505-6482_7-33089579.html
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 21, 2010 | Sansui HDLCD-1900 19 in. LCD Television
I have a Toshiba Portege 3500 with rotating LCD screen, my problem is that I can not rotate the wiew of the screen. The settings were changed, and now I can not rotate the view again. Thanks for your...
Do you have Windows XP with servicepack 3 installed? If so then there is a known problem with the screen driver and XP sp3. Go bakc to SP2 and reinstall de display drivers this should clear the problem.
If anyone has working tident drivers for XP SP3 I would be greatfull!!
Aug 04, 2010 | Toshiba Portege 3500 Tablet PC
Wiew finder not warkig.
on most cameras you cannot set the lcd and the viewfinder at the same time, there should be a button that says 'LCD/EVF' or another button, it will be in an online manual
http://finnsharp.daportfolio.com/
Apr 16, 2010 | Canon Rebel XS / Eos 1000D Digital Camera...
Sansui 1908 sound but no picture, kid was using
Return the thing. Ur LCD inverter board is dead.Or call for warrenty repair.The LCD inverter have no set of times,it dies anytime.Must replaced the LCD inverter board to get picture back.
Nov 06, 2009 | Sansui 19 in. LCD TV
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
TV isn't displaying pc image
Double check your refresh rate. It must be set for 60hz for Sansui tv's.
Dec 30, 2008 | Sansui Televison & Video
Hi, I have a Sansui high
i have same problems has any resolved this yet??
Mar 25, 2008 | Televison & Video
 Grubhead
Grubhead
