Question about Polaroid Photography
Battery gets stuck - Polaroid Photography
  • Brad Brown Sep 07, 2015
    Hi Christiana Ming, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Christa Morrone
    Christa Morrone Sep 07, 2015
    hi I'm actually having the same problem with my Polaroid z2300, the battery won't come out of the bottom even when I hit the little tooth like piece to release it, i dont know how to get it out now
I have a SV1106-FS. Today the vac stuck and would not shut off. The on/off button was stuck. We had to disconnect battery to stop. Is the button broke or can I take it somewhere to get repairs.
If you are capable of repairing yourself, it is cheaper that way.
Replace the switch. Get it from the manufactured with a schematic on how to do the setup.
Jan 04, 2015 | Shark Vacuum. Navigator FreeStyle Premium...
Can a bad battery cause the key to get stuck in the ignition?
No, a bad battery can not cause this problem, but was the ignition stuck in the on position? That would make the battery go dead. A lock smith might be able to help you.
Sep 20, 2014 | Chevrolet 2005 Chevrolet Cobalt Radio
My battery died. After trying to start my car the key is now stuck in ignition, shifter stuck in park, no brake lights. I charged the battery and only get the cluster lights.
Hi there all the things you explain are and need power to operate, make sure your battery has 12.6 volts or more and try again , if your battery doesn't have that voltage then you will need a new battery, hope this helps
May 14, 2014 | 2007 Chevrolet Impala
Battery stuck
I would remove, or at least loosen the housing screws that hold the saw together. I would guess that it overheated and may have melted the plastic if the battery is stuck in the saw.
May 05, 2014 | Dewalt Drills
Can't get battery off
off?
you cant remove it. the bolts are rusted? use penetrating oil there.
the lugs are stuck.
just a clue as to the 3 parts of battery that are stuck.
Feb 04, 2014 | 2007 Suzuki XL-7
My samsung sch-u485 keeps getting stuck on the verizon logo as i try to turn it on and thats where it gets stuck
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 02, 2012 | Cell Phones
HP Pavilion dv6700 battery stuck
Make sure the battery is in good, then keep applying pressure to the latch.
Mar 29, 2012 | Computers & Internet
Sony t20 battery stuck inside
Open the battery cover, shake the Camera and HIT slowly on the hand by putting the battery side down.
Mar 06, 2012 | Sony Cyber-shot DSC-T20 Digital Camera
Screen stuck on battery life indicator
My guess is the battery was just changed? This watch needs to be cleared when the battery is changed. I recommend seeing a watch maker/technician to have the circuit board AC'd.
Sep 20, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
CD Player get stuck after dead battery
hi..
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly...
thank u
rate me!!
Jul 27, 2009 | 1998 Lexus LX470
Photography Logo
345 people viewed this question
Top Polaroid Photography Experts
luminos8
Level 1 Expert
danoyachtcap
danoyachtcap
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
