Question about Dryers
Fault code f07
Any program, timed or sensor, starts , after approx 5 minutes f07 flashes. A little heat is produced, then becomes cold. Sometimes program stops, sometimes it continues running cold. Always flashes f07
  • 22 Answers
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Posted on Dec 31, 2013
  • Andy Jefferson
    Andy Jefferson Dec 31, 2013
    Apologies if not clear Stanley, although I did type in Hotpoint TVF770P in the drop down before I posted?? Thanks for your reply. What is the lower element? There are 3 coils on the back of the machine. Does it refer to one of them?
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Posted on Aug 21, 2007
TheMobilian
  • 8220 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
Posted on Mar 14, 2009
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
Aqualtis fault code f07
Heater relay stuck
  • Check wiring
  • Check electronic control PCB
Jun 21, 2014 | Hoover Washing Machines
Bosch classixx 1200 washing machine. There was a power cut and now it won't work. tried leaving for 20mins with it set for a wash cycle. All spin lights flashed as did the wash programme light. After...
Before you investigate the fault, try unplugging the machine at the mains for 20 minutes. This MAY reset the problem and all will be well. If that fails, then read on:
The flashing lights are an error code. You will see that there are a series of rapid flashes followed by a pause and then the series of flashes will be repeated, this is the error code being displayed. If you count the number of flashes being given then you use that number to correspond to the fault code, for example, three flashes would be fault code 3.
Fault Code 1 notlit.gif notlit.gif lit.gif Door open after program has been startedThis error code may well not show up for a minute or so after you actually go to start the washing machine but the door can be closed and the program restarted.
If the error persists there may be a fault with the door locking mechanism or door latch.
Fault Code 2 notlit.gif lit.gif notlit.gif Water intake has failed
Error after more than 10 minutesa failure of the water inlet valve or the water supply itself has been cut off somehow. This can be due to the water valve or supply as stated but it may also be worth checking the filters in the fill valves to ensure that they are clear.
Fault Code 3 notlit.gif lit.gif lit.gif Heating time exceeds 105 minutesThis would ordinarily indicate a fault with the water heating element or, certainly, the water heating circuit as the washing machine is indicating that it has failed to reach temperature.
The error can be caused by faulty wiring, the heater as stated, low voltage or even a calcified heater has been known to generate this error code.
Fault Code 4 lit.gif notlit.gif notlit.gif Takes longer than 6 minutes to drain.Very often you will see this error if the filter is blocked or obstructed or the drain pump is jammed or faulty.
This error code can also be caused by the pressure sensor being blocked by overfoaming from overdosing detergent or using a poor quality detergent as well as a pressure switch or sensor failure.
When this error occurs the program is aborted as it is considered to be a "fatal error" without any attempt to drain the washing machine.
Fault Code 5 lit.gif notlit.gif lit.gif NTC thermistor open circuit or short circuit
Self explanatory really, either a faulty NTC or wiring. The washing machine will complete the program but will not heat.
Fault Code 6 lit.gif lit.gif notlit.gif Unexpected heatingThe machine has attempted to heat at a stage in the program where it should not.
Fault Code 7 lit.gif lit.gif lit.gif Fault detected in motor or drive circuit
Very often you will see this error if the carbon brushes or the motor fails.
This error code can be generated by no tacho reading from the motor (the electronics cannot see the tach generator of the motor), a triac fault or short circuit or a faulty reversing relay on the control board. The washing machine will try to start the motor but after several attempts the program will be aborted with this error code which is again consider to be a "fatal"
Jul 05, 2011 | Bosch Washing Machines
I have a 90 Lexus 400 LS, when engine is cold it idles on regula 1500rpm. When it warms up it drops to normal rpm. But if i turn it off for more than thirty minutes, it idles back to 1500 rpms and it takes...
You need to test your Engine Control Unit (ECU) for fault codes.
This could be caused by several things:
- Coolant Temperature Sensor or circuit
- Intake Air Temperature Sensor or circuit
- A/C Signal circuit
- Power Steering Pressure sensor or circuit.
- Neutral Start Switch circuit
- Throttle Position Sensor or circuit
- Idle Control Valve or circuits
- ECU
You can check fault codes by placing a jumper between terminals E1 and TE1 in the check connector.
(See pictures below) Turn the ignition switch on and count the flashes of the Check Engine light.
If it flashes 2 times every second, this is normal (No codes present). If a fault code is present, the first group of flashes is the first digit in the 2-digit code. There will then be a 1.5 second delay and the second digit will be output. If there is more than 1 code present, there will be a 2.5 second delay, then the nexy code will begin tobe output.
It is recommended that you read the codes (flashes) several times to make sure you are reading them correctly.
May 21, 2011 | 1990 Lexus LS 400
I turn my indesit is70c tumble dryer on and after a minute it trips the rcd. I then reset the rcd and turn it back on and it runs for about a minute and then trips the rcd again. Can anyone help me with...
this could be the hater or the motor but sometimes just chafed wireing
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
We have a full video library on appliance repair video’s
Jan 03, 2010 | Dryers
No hot air blowing - cold air only. Hotpoint Aqurius condenser dryer.
Common faults -
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Jan 02, 2010 | Hotpoint Dryers
Inglis IS8200 Dryer not producing heat.
Common faults -
You-Tube video "75l_AtpGkks" placeholder (do not delete)
Jan 02, 2010 | Dryers
Drivers side seatbelt connected When truck is
sensor in the seat belt bukle needs to be replaced
Aug 01, 2009 | 2004 Ford F150
2004 Cadillac Escalade knocking noise
Make sure oil level is adequate.
Also, this could be an exhaust leak that is being closed as the manifold and/or block heats up.
Mar 02, 2009 | 2004 Cadillac Escalade
Dryers Logo
366 people viewed this question
Top Dryers Experts
