Question about Crosley CR248 Turntable
Hitachi turntable won't spin
Turntable won't spin
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
Aiwa lx-110 turntable won't spin
chances are that is the drive belt for the platter, check you local radio shack, they used to carry or be able to order those kinds of things
Mar 09, 2013 | Audio Players & Recorders
Turntable won't spin, even after switch the tonearm right
Hi, most likely the belt has come off or is stretched. Cheers John. Styluscity
Nov 22, 2012 | Crosley 0187SST Turntable
Hitachi Ht-354 direct drive. Why can't speed be adjusted?
Direct Drive turntable's have electronically controlled motors with complicated systems to keep them at the right speed.
My guess is that there could be a power supply issue that feeds one of the motors that is sending a much higher voltage to it. But that's just a guess. You might want to look around for the service manual for it to see how the motor is controlled.
May 01, 2012 | Audio Players & Recorders
I have a Hitachi 12V Cordless Impact Driver that won't spin at the chuck housing. Not sure what the problem is?
Make sure it's all the way in gear. It sounds like it's not all the way in first or second gear. Yes it sounds dumb, but it's one of the most common problems we see in our shop.
Apr 26, 2012 | Hitachi 12V Cordless Impact Driver
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
My turntable won't spin - the spindle is fine and it makes half hearted efforts to move but will only **** a few times and then stop.
The self-lubricating bushing in the turn-table is dried out. This is a difficult problem to solve and best left to an expert. Don't expect great results.
Sep 06, 2011 | Stanton ST-150 Turntable
Crosley CR248 Turntable Logo
46 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
