Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Bosh dishwasher still full of water when finished
4 Suggested Answers
  • 641 Answers
SOURCE: bosh exxcel dishwasher heater problem
Check with multi-meter for power on the heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Posted on Sep 09, 2007
  • 17 Answers
SOURCE: no hot water in dishwasher
there is a heater in the base of the dishwasher . It could be this is faulty as you can still use the machine .
It does'nt matter that you have connected it to the cold water tap the machie should heat up the water it self.this is'nt a job you can do your self so you will have to call out an engineer sorry
Posted on Dec 11, 2007
SOURCE: Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Posted on Feb 14, 2008
My bosh shu33a06uc dishwasher is stuck in water discharge cycle. It will run untill door is open.
This error means your dishwasher has water in the pan below your tub. You need to remove toe plate below the door and soak up the water in the pan to reset the motor.
Good Luck
http://www.appliancerepairlesson.com
Mar 06, 2011 | Bosch SHU3306UC Built-in Dishwasher
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
The water does not circulate throughout the washer. Is the pump bad? The full cycle will run without cleaning.
Before we jump to conclusions, you can try to clear element that discharges the water. The wholes in these units can become clog do to the detergent as well as food. Most Bosch units allow you to unscrew these pretty easily. Blow through them, or use a plastic tooth pick to clear any obstructions or both. Before you reattach, turn on dishwasher and listen to hear how much water is shooting out at the discharge points. Most Bosch have two discharge points one for the top and of course one for the bottom. Reattach units and Run dishwasher.
Should this fail it could very well be the circulating pump.
Oct 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher Bosh Model SHU43C06UC has the drain clog
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Apr 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Jan 02, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
14 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
