Question about Tablets & eReaders
Turned off but will not turn back on
The tablet switched it`s self off but will not switch back on I have tried pressing the switch down for 8 seconds as well as the next button then tried to switch it back on but it did not work
  • ka4iup
    ka4iup Dec 31, 2013
    Hi Sylvia Grubb, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What type of tablet are you having problems with, and what software version is loaded on it. I had a similar problem that I solved with my Nexus 7.
joelwilcox
  • 1274 Answers
SOURCE: On a seperate tablet PC I accidentally switched to
turn the pc off and turn it back on, when it boots back up hit the fn key for lcd/external monitor until it works by turning it off of course i mean hold the power button down for 8 seconds
Posted on Nov 03, 2009
  • 228 Answers
SOURCE: hp elitebook 2730p I left
Either your laptop had gone to sleep or hibernate mode. You can set the timers under Power Options on the Control Panel for the laptop to go on sleep mode or hibernate mode if idle for span of time.
You can wake up the laptop by touching the touchpad, pressing a key or pressing the power button.
However, if above options will not work, the only option for you is to press and hold the power button for at least 5 seconds to completely turn off the unit. Try to power on the computer if it will boot up okay.
***ADDITIONAL NOTES FOR CASE TO CASE BASIS**
If you still get black screen, remove the battery and the ac adapter (charger) then press the power button for at least 20 seconds to discharge power in the motherboard. You can now reinsert the battery and power on the system normally.
***NOTE: If the computer will not boot up, the LCD or the motherboard might have failed.
Hope this helps.
Posted on Jul 11, 2011
SOURCE: my archos 28 internet tablet wont turn on... the light comes on and then it goes off after like 7 seconds
LOL, you're up the creek. Never buy a computer that does not have a CD Drive on it because that is what you need now.
May the AC Adapter Power Cord is bad. Some of them have a indicator light on them when you plug them in the wall. Does yours have a light on it and does it light up?
When you plug the power cord in the tablet do you see any lights?
Posted on Apr 25, 2012
SOURCE: Samsung Tab p6800 frozen up, shut down later but not coming back on!
wait can't you just reset it with a needle? i thought most android tablets have this feature. well hopefully this helps some
Posted on Sep 22, 2012
benjamin_951
  • 53 Answers
SOURCE: my tablet is not powering on..it is getting charge
Two most probable problems:
-bad battery
-bad motherboard
If it's still under warranty, get it repaired.
If not, buy a new one
Posted on Oct 13, 2013
Cannot log in or turn off tablet to reboot. Touch screen not working.
You should be able to press and hold the power on switch for several seconds and get the tablet to shut down. If it won't shut down with the power switch, leave it on until it shuts off due to low battery and then recharge and try rebooting the device. If it won't reboot after that, check your manual for the factory reset process. See if you can contact customer support for your unit and get the process for re-flashing the bios from them. That usually requires loading a specific set of files onto the external memory SD card and holding down a switch when restarting the tablet. All files and downloaded apps will be erased if you have to go that way.
Apr 25, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Turn on the tablet
press & hold it for 6-8 seconds & see what happens
Feb 07, 2015 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
Coby Electronics Corporation Coby Kyros MID9042-8 9" 8 GB Tablet Computer - keep shutting down
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 23, 2013 | Tablets & eReaders
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Apr 20, 2013 | Coby kyros Tablets & eReaders
On a seperate tablet PC I accidentally switched to dual clone mode but television, not monitor and now neither tablet nor monitor output works and it stuck in shut down saving mode, how can I restote...
Nov 03, 2009 | ASUS R2H Tablet PC
Tablets & eReaders Logo
29 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
