Question about Cell Phones
How to root Etisalat E-20
Intel BT230
Find root file ubuntu os
Switch to 14.01 or mint.....Or check if anything in directory has been tampered with or bottle-necked....
Feb 06, 2015 | Intel Netbook 10.2 inch,1G,160G Intel Atom...
Etisalat sim block
You can actually try putting your etisalat sim card to another mobile and try if its working. If not report it to Etisalat Office as soon as possible.
Hope it helped you!!
Kevin Peter
Jan 18, 2014 | Nokia 3230
COMPAL EAL51 barebone
Here you go:
1394
VIA OHCI Compliant IEEE 1394 Host Controller
BATTERY
Microsoft AC Adapter
Microsoft ACPI-Compliant Control Method Battery
COMPUTER
ACPI Uniprocessor PC
Diskdrive
Universal HDD
DISPLAY
Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC
Primary IDE Channel
Secondary IDE Channel
Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED
SMC IRCC - Fast Infrared Port
KEYBOARD
Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA
Audio codecs
Video Codecs
Midi Control devices
Legacy Video Capture Devices
Legacy audio drivers
Microsoft Kernel System Audio Device
WDM Audio Compatibility Driver Microsoft WinMM
Realtek AC'97 Audio
MOUSE
PS / 2 mouse
NET
1394 Adapter
Remote network engine Miniport (IP)
WAN Miniport (PPPOE)
Parallel Direct
IR
Realtek RTL8139 Family PCI Fast Ethernet NIC
WAN Miniport (L2TP)
WAN Miniport (PPTP)
OTHER DEVICES
PCI Modem
PCMCIA
Generic CardBus Controller
PROCESSOR
Intel Processor
SDHOST
SDA Standard Compliant SD Host Controller
SYSTEM
Generic Bus
Button ACPI resource sixed
Button tie / Untie ACPI
The system CMOS / real-time clock
Direct access memory controller
Programmable Interrupt Controller
Microcode update device
Microsoft System Management BIOS Driver
Software Device Enumerator Plug and Play
Logical Disk Manager
Manager volumes
Intel (R) 82801FB/FBM SMBus Controller - 266A
Intel (R) 82801FBM LPC Interface Controller - 2641
Intel (R) 82801 PCI Bridge - 2448
Microsoft ACPI-Compliant Embedded Controller
Microsoft ACPI-Compliant System
Microsoft Composite Battery
PCI bus
PCI standard host CPU bridge
ISAPNP port
Terminal Server Device Redirector
ACPI
Terminal Server Keyboard Driver
Terminal Server Mouse Driver
System Timer
UNKNOWN
PCI FLASH memory
USB
Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Intel (R) 82801FB/FBM USB Universal Host Controller - 2658
Intel (R) 82801FB/FBM USB Universal Host Controller - 2659
Intel (R) 82801FB/FBM USB Universal Host Controller - 265A
Intel (R) 82801FB/FBM USB Universal Host Controller - 265B
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
VOLUME
Generic volume
Jun 19, 2012 | Computers & Internet
I want to block my etisalat sim card
Hello, welcome to Fixya!
Contact your service provider. Your service provider alone are the ones that can block the line for you.
Calling your service provider is toll free from an Etisalat line.
Regards.
Jan 04, 2012 | Samsung Cell Phones
Panasonic sa-bt230 reciever replacement ?
WWW.EBAY.COM IS THE BEST ANSWER FOR YOU.
Since your in the UK you might try ebay.uk. I am sure you can get another head unit that would work with the speakers as speakers can be universal!
Dec 18, 2011 | Audio Players & Recorders
My panasonic SA-BT230 stops playing iPod after 30 minutes. I own two iPods and have the same results. I look for a sleep settings in the BT230 and did not find anything. At this point I think maybe a...
I don't like to add the " I have the same problem too" comment but I am in need of a solution to this problem as well ... I can confirm that it does not shut off on any other source only the iPod ... When my iPod is in my Bose dock it never shuts off after 30 min ... I too checked to see if there is a sleep function within the panasonic but nothing there that would indicate a sleep mode or a inactive shut down I mostly use my iPod for pandora I have not tried it to see if it will do the same for music store on my iPod
Mar 15, 2011 | Audio Players & Recorders
I am having trouble connecting my Panasonte SC-BT230 to my cable box and my TV. Do i connect my cable box to SC-Bt230 than to my TV or my SC-BT230 to cable box than to TV
Here are a few ways to go about this.
connect the cable box hdmi (if Capable) to the panasonic hdmi input. Then connect panasonic hdmi out to tv hdmi in. The easy thing about this setup is that you only need the two hdmi cables because they carry both audio and video.
If your cable box or tv are not hdmi compatible, Then connect video output from cable box directly to your tv, and send an audio feed from your cable box to the panasonic.
Hope this helps,
Good Luck
Jan 07, 2011 | Panasonic Home Theater System System
Is panasonic sa-bt230 vs sc-bt230 the same?
sc-bt230 is the name of the whole system, sa-bt230 is the name of the main unit only
Sep 29, 2010 | Panasonic SCBT230 Theater System
Belkin Wireless N+ router - can't connect to Etisalat in UAE
you could try updating your router's firmware.. it fixes a number of bugs and makes the web interface multi-lingual. This version supports English, German, French and Spanish.
Feb 10, 2009 | Computers & Internet
I NEED DRIVER UPDATES BUT I DONT HAVE A REG.KEY....
hiiii ther
how r u ??
go to acer.com u will findall the vista update to ur driver
but 1st u need to check if ur machine is compatible with vista if it is
u will find all the update on the acer.com under ur laptop model
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | Acer Aspire 3680 Laptop
Cell Phones Logo
264 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
