Question about Health & Beauty
Conair trimmer hc112wv
Reassembly of blade to comb...it has screws
SOURCE: reassembly of trimmer blades to stihl HS 80 hedge trimmer
My request from you was for a schematic of assembly for my stihl HS 80 hedge trimmer. You did not send but rather gave general advice. I solved the problem by calling a small engine repair shop and asked them to fax me a photo copy. You all were of no help and appear more to want money via bait and swithch. THUMBS DOWN to you!
Posted on Mar 20, 2009
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
clipperdoc
  • 17 Answers
SOURCE: How to install included shaving foil on Conair GMT
email, me at askmannyssharpening@yahoo.com and I'll send u a picture on how to do this on Conair GMT 400, Please send me the info that u are asking
Posted on Nov 14, 2009
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I have a Conair GMT189CGB 13 piece styling trimmer how do I change the nose/ear trimmer? I have no idea how it snaps in? what a terrible design!
You do not need to unscrew anything. Instead, simply take the beard trimmer (with the beard shaving blade still screwed on) in your hand, with the power button and "CONAIR" logo facing you. Then, put your thumb under the shaving blade and apply force to pop it off. So, the shaving blade, and the top part of the unit that it's screwed into will simply pop off. Then, you simply align the nose/ear hair attachment, and snap it in to the beard trimmer unit.
Jan 16, 2011 | Conair GMT 170 CS Beard Trimmer
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Mar 23, 2010 | Conair HC117 Hair Trimmer
I bought a 19 piece and i can't cut my hair
It soulds like the blades are too far back. There is an adjustmebt piece to the right or left of the blade that is about 1 1/2-2" long and it slides forward and backwards.
Ths will adjust the blade depth. It sounds like the blades may be set too far back to cut your hair, this has to bring the 2 blades together so you have much less free edge on one side, so what you do is slide ths blade by adjusting the handle and bring the blades to just where one side is slightly shorter than the other less than 1 cm. Then make sure the guard is off and slde the adjustment head is set and then try it agan. Unusually it is the problem if it does not cut or the blades have come loose. Hope that helps.
Apr 05, 2009 | Conair HCT-426 Hair Trimmer
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Conair hc318d reassembly
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
HOW AM I SUPPOSED TO "OIL" OR LUBRICATE A CONAIR HC115BPCS HAIR TRIMMER?
There should be 2 phillips head screws on the underside of the cutting blades.loosen them enough to where the 2 cutting blades are able to move freely then take some 3-in-1 oil and apply some in between the blades and tighten the bladesback down.Turn the cutters on for about 30 seconds and they should be good to go.Rate me FIXYA! if this helps! GOOD LUCK.
Nov 18, 2007 | Conair HC115BPCS Hair Trimmer
Health & Beauty Logo
90 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
