Question about Music
We have connected an iphone to the Digitech aa0478 but the music is stopping and starting
The sound coming through the amplifier is fading in and out at times. We have connected the amplifier to a iphone and imac computer with music. The sounds are good for some time and then starts fading in and out.
5 Suggested Answers
  • 5603 Answers
SOURCE: Digitech RP3 Guitar signal processor only lights up.
Check that connectors are seated AND the input and output are correct.
Sometimes1/4 inch plugs are not seated correctely. The power adapter plugs are notorious for not making contact.
Posted on Oct 28, 2009
  • 1138 Answers
SOURCE: hiwhat is the best way to connect my DigiTech RP10
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Posted on Oct 23, 2010
  • 10 Answers
SOURCE: Amplifier not working
It is more likely that your input jack component is broken or damage you would have to take it apart because your circuit board may need a look at to check for damage and you will need a new input jack
Posted on Aug 11, 2011
  • 5603 Answers
SOURCE: my digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Posted on Sep 16, 2011
My digitech rp 500 has power supply but it won't
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
One side stopped workig on my 2600 amp, so i am running thru center out put. now sound fades up and down.
Please be advice that the center output connector is only for BRIDGE mode operation, you should not use that way, try to clean all the back switches with a cleaning solution spray, clean all switches and check amp functionality again in stereo mode.
Jun 13, 2011 | Peavey Pv 2600 Power Amplifier
The foot pedal (not the switches) on my "DigiTech RP90 Modeling Guitar Processor does not work...it will move but it changes nothing.
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Jan 13, 2011 | Music
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
My rp90 digitech had stopped ..once i plug the electricity the led screen writes 88 and all the leds lights and it does not change or operate to the presets what can i do
Check the power adapter. It sounds like it is the wrong unit or it has failed and is not producing the correct voltage.
Jan 31, 2010 | DIGITECH Music
It lights up but doesnt put out sound
A friend of mine had the exact same problem. In his case the pedal is only good for hammering nails now. If it still has it warranty I'd say look into that, if not you've got nothing to lose. Open it up, look for unattached wires. Also, try using a battery instead of an AC adapter..
Oct 26, 2009 | Digi-Tech Digitech X-Series Synth Wah...
Oct 26, 2009 | Music
Music Logo
37 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
