Trying to connect my laptop to the tv
Get sound but no vision
  • 2 more comments
  • sandra roberts
    sandra roberts Dec 31, 2013
    VGA 15pin and AWA 106cmPDP TV. I tried what you mentioned on 2 different laptops it didn't work. The TV is connected to a topbox. would this make any diffence?
  • scotland1808 Dec 31, 2013
    The correct question is, what do you have your laptop connected to? You can't go thru the Topbox, you need to go straight into the TV's 15 pin port or HDMI port depending on the laptop. The Topbox is a cable convertor to supply signal to the TV - it usually has no means of accepting local input signals. I'd need details on it to be sure. Another thought, make sure you are selecting the correct input on the TV. It should be on PC or whatever they use to describe the VGA input.
  • sandra roberts
    going from laptop to tv with 15pin port and selected VGA on tv
    OK, VGA and audio direct from LT to TV, and on the right input. How long is the VGA cable? What type of LT? Mac or PC? Are you using any type of adaptor between LT and VGA cable? Could be a bad cable. Check the pins at both ends and make sure none are bent or appear short, as though pushed in. Also make sure that each connection is seated properly and locked in by the set screws. The simplest things sometimes defeat us. REcheck the function key settings that you are actually switching. The best way is if you have an external monitor to hook up to, although that is almost the same as your TV, but there are a couple of differences. Even without it you should see the LCD blank on at least one of the turns which means it's sending signal to the port. The port may be damaged. You may be having an EDID problem (usually with Mac's), or if everything is brand new, a HDCP problem that is preventing the signal to be output because communication KEYS are absent. This usually only applies to HDMI signals but some new devices may be set to block analog output to digital receivers. Let me know how that goes. Is the LT new or old? What operating system? Later.
  • 3 Answers
Some details are needed - what type of connection from laptop? VGA 15pin or composite video for example. What kind of TV - I assume some modern flat panel. Did you use the function key on the laptop to send the video signal to the external port. Audio gets supplied to the audio port all the time so that is why you have audio, but the video signal is normally directed to the LCD screen. The function key (F5 or F7 typically) changes this and blanks the LCD and send the signal to the external ports. Press again and you get both LCD and external ports together. This is absolutely the most common problem with people hooking a laptop up to an AV system or device.
Posted on Dec 31, 2013
Bang olufsen tv
Check its back-light comes ON or not. Contact any service technician.
Oct 27, 2013 | Televison & Video
Vision quest tv
1. check if cables connected to the correct ports.
2. do you have a pvr or are you directly connected to wall cable.
A little more on what you have tried so far. Sound?
Aug 12, 2013 | Televison & Video
I can only get sound through headphones and not tv speakers
Check the speakers. If found OK, check and repalce headphone socket.
Aug 07, 2013 | Bush Televison & Video
How do you connect a fujitsu p42vca30eh to a BT Vision box? Which cables are needed? Thanks Emma
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
Mar 02, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
Hi I bought a second hand fujitsu tv and Im trying to connect to bt vision because the connections are different i am using a pin to scart cable it works ok but there is no sound and the tv stays green , I...
I also have the same problem. I think maybe getting an electrician out is our best bet. The cables and connections are so confusing. Hopefully you manage to sort your tv out. It may be an s-video cable that you need. I think I may try that.
Emma
Feb 28, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
Double vision
This is normally caused by cable/antenna connections
  • Unplug all cables from TV and receiver
  • Plug them back in.
  • Check antenna location and the direction
  • Try another cable for TV connection to receiver.
Jun 14, 2010 | LG RU-44SZ51D 44" Rear Projection...
I cannot connect the laptop to the tv (hitachi ultra vision)
Connect them using the VGA port, start the tv and reboot the laptop, .right click on display / Screen resolution, click on the second one, set the resolution to the tv's one, select in Multiple displays the Extend option and click OK
Mar 13, 2010 | ASUS Computers & Internet
Video works but no sound at all
yee..check if you connected phono cables and try turn on and off your telly. yellow-this is vision,,,red--right channel,,,white-left channef of your sound...try also in menu options
Jul 12, 2009 | Magic (ED8000) Professional Microphone
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
