Question about Gateway MT6451 Notebook
Heat processor what is the cause of overheating?
    Top Expert:
  • Gateway Master
  • 22,699 Answers
Probably a blocked air way, using a laptop on a soft surface that restricts the air flow, faulty fan etc.
Posted on Dec 31, 2013
Overheating
Hello, welcome to Fixya!
Over heating maybe caused as a result of weak fan, ineffective heat sink, (dried thermal paste on the processor) or dust around the fan area in the system preventing free passage of air.
Also, where you keep your laptop when using it matters too. If you place your laptop on a foam, rug or too close to things preventing free passage of air may cause overheating.
You have to disassemble your laptop, and use a paint brush to remove every dust around the fan. Also, apply thermal paste on the processor to reduce the heat.
If you don't know how to disassemble your laptop, then you need someone to do that for you.
Take care.
Oct 24, 2015 | Computers & Internet
Overheating issues with laptop
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Make sure your dint restrict the speed of CPU fan.
Use proper ventilation in your room
Shut down your computer at least two hour a day
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of overheating
Sep 23, 2013 | Toshiba Satellite Computers & Internet
Sony VAIO VGC-RA810G Desktop overheats and freezes.
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Stop Overclocking your CPU
- Make sure your Heat Sink is placed properly above the processor
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
Sep 16, 2013 | Sony VAIO PC Desktop
Fan dose not slow down
It seems that your system is overheating so follow these instructions first
- Shut down your computer atleast two hour a day
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of overheating
Aug 27, 2013 | HP TouchSmart Computers & Internet
Overheating
CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heat up beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heat up.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heat sink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 27, 2013 | Intel Computers & Internet
How to overcome overheating issue in my desktop?
Depends on what's overheating. If it's you processor you have to replace the thermal paste between the heat sink and the processor, if it's the ram you need to make sure it has proper ventilation, if it's the hard-drives the same etc. You need to be more specific.
Oct 19, 2011 | Computers & Internet
Toshiba Satellite L500D is shutting down by itself OVERHEATING Clean the fan with compress Air ....> NO GO Need help Please or Any other Suggestion
Disassemble the laptop and remove the heatsink.
Remove all the dried up heatsink goo that's on the heatsink and processor.
Squeeze a small amount of QuickSilver heatsink compound onto the middle of the processor top.
Place the heatsink on the processor and move it in a couple small circles before locking the processor heatsink back in place.
Clean the air vents and cooling fins well while the unit is open.
This should fix any overheating issues you are having (assuming the fan is OK)
If the fan isn't running, replace it.
Jun 24, 2011 | Computers & Internet
HP PC m7250n- fan always on high speed
question = are u over clocking ? and /or is your processor fan and fins dirty causing over heating causing the fan to run on high trying to cool down a heated/overheated processor.
May 01, 2010 | HP Media Center m7250n (ED842AA) PC...
Acer aspire 5610z
need more info....does it replicate without the battery? If it does, then it may be that the processor is overheating and shutting down the computer. Try to run with just the power adaptor and see if it happens. If it doesn't, then its probably the battery....
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
Gateway MT6451 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
