Question about Sansui Audio Players & Recorders
Sansui am70 output per channel - Sansui Audio Players & Recorders
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
I have an old Sansui 400 receiver. I get no sound from the left channel--both A and B speaker options. The speaker and wires are OK, because they work when hooked to the right channel contacts.
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Jul 23, 2010 | Sansui Audio Players & Recorders
Wattage
I have the following specs for you
Basically 150watts per channel using two channels , or 75watts using all four
Here goes:
  • 4 Channel Mosfet Amplifier
  • Advanced Overload and Thermal Protection
  • Metal Film Capacitors/Resistors In Signal Path
  • Frequency Response +/-1dB, 20Hz to 20 kHZ
  • Signal to Noise Ratio (A-weighted) >100dB
  • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
  • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
  • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
  • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
  • Minimum Load when Bridged 2 Ohms
  • Minimum Load per Channel 1 Ohm
  • Input Signal Voltage Range 0.1 volts to 2 volts
  • Crossover Type Resisitor Network, Linkwitz Riley,
  • Highpass/Lowpass
  • Crossover Slope 24 dB per octave
  • Crossover Frequency Range 20-550Hz
  • Factory Crossover Setting 85 Hz
  • Auxilary Output Channels 2
  • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
  • Bass Boost 0- to +18dB @ 45 hZ
  • Power Supply Voltage 10Vdc to 15.5Vdc
  • Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
May 23, 2010 | Car Audio & Video
Hello, I have a sansui G8000 and no operating instruction and I was wondering how many watts per channel. Do you sell the operating instruction? thanks from california
Hi malonzocarlo
To answer your question;
This unit puts out a 120watts rms per channel.
I don`t have the user manual but you can get the service manual HERE
It has all the specifications.
Have fun. Cheers
Mar 10, 2010 | Audio Players & Recorders
XR 8600 what color wire on the output connects
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
Feb 20, 2010 | Music
I have a 2003 Sansui VRDVD4005 recorder. It currently playsback on channel 4 on my TV and I need to reset it so it plays back on channel 3. Do you know how I can make the change? All suggestions on the...
Turn off the unit. press and hold the "3" button on the remote until you see "rf 3" in the display on the VRDVD4005. This will change the output channel to 3.
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Crown amp xs900 will not reset
naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
Features
  • 2-ohm dual (per channel) : 1200W
  • 4-ohm dual (per channel) : 900W
  • 8-ohm dual (per channel) : 600W
  • 4-ohm Bridge : 2500W
  • 8-ohm Bridge 2100W
  • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
  • Housed in a rugged, all-steel 2U chassis
  • Microprocessor-controlled protection system.
  • Flow-through ventilation from front to back.
  • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
  • EIA Standard 19-inch rack mount width
  • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
Inputs
  • XLR-¼" combo connectors: One per channel
  • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
  • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
Output
  • Balanced XLR connectors (2-channel models only)
  • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
  • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
  • 4-Pole Speakon output connector (2-channel models only)
  • Accepts a 4-pole Speakon connector.
Dec 31, 2008 | Crown XS900 2-Channel Amplifier
Inquiries
Straight from the product's manual...
Amplifier section
Power Output-
[Stereo Mode]
125 watts per channel
[Dolby Pro Logic Mode]
Front
120 watts per channel
Rear (Surround)
60 watts per channel
Center
120 watts
Click HERE for the manual.
There you have it.
Cyryl
Nov 10, 2007 | Aiwa AV-X220
24 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
