Question about Compaq Computers & Internet
Windows 7 has a password that has stopped me from using my computer as i can't get passed the login stage
My computer reset itself and now it is asking me for a password that i have not put on so i can't get onto my computer how can i bypass this and get onto my computer and set a nwe password
    Guru:
  • 450 Answers
Try to bypass Windows 7 password with tutorial help: http://www.windowspasswordsrecovery.com/win7/bypass-windows-7-password.html
Posted on Jan 02, 2014
Hanto
  • 226 Answers
SOURCE: password
that is because the password in question that you are trying to get past is the BIOS password most likely. Verify that your computer is turned off, remove power cord from back of computer, and find the jumper near the Bios chip on the motherboard. It will usually be close to the battery ( another option, temporarily remove the battery for about 30 seconds, then replace the battery into its proper position ). Be careful when you do this as some battery sockets are a pain to work with. Anyway in nearly all cases, the Bios reset jumper is located very close to both the battery and the bios chip ( firmware ). Removing the Bios reset jumper and positioning it one pin over from the initial position will usually reset the bios and get rid of the bios password requirement. Always put the bios reset jumper back into its initial position before re-appying power to the motherboard. Be careful not to leave anything loose lying around on the motherboard or in the case, else you might fry the motherboard..
Once you have successfully managed to get past the Bios password, then you should see the computer start to boot up normally and prior to Windows boot up and in the Bios routine you can configure the computer to boot to CD first. In many more modern situations, the motherboard is already configured that way.
Posted on Feb 23, 2008
map9966
  • 2351 Answers
SOURCE: I am trying to bypass
If you can not enter your operating system because your being asked to type in the password than you will not get into windows unless you re-install windows or have the correct password. If you can not get into your bios because you or someone else set a password up for the bios. You can re-set the bios by clearing the bios settings. This entails moving a jumper on the motherboard to clear the bios & than re-seating the jumper to it's default setting. After doing this you'll have to enter the bios & re-set up all the settings for the system or your operating system may not load correctly.
Posted on Mar 05, 2008
BobbyR1234
  • 173 Answers
SOURCE: Reset Admin Password on used computer.
Ok, what I am going to do is show you how to bypass or (hack) a password protected windows xp computer. first, restart your computer>press F8 before it boots up, a menu will come up>select safe mode>restart in safe mode>the admin account comes up> click on it and click yes when the small menu comes up> the computer should boot to the desktop now>select start>control panel>select user accounts>select change account and follow the prompts to creating a new account (make sure that the administrator radio button is selected) put in your new password, etc> restart your computer. You should now have administrator privileges on that system. Let me know if you have any further problems. :-)
Posted on May 26, 2008
byron21
  • 151 Answers
SOURCE: My son set a password on a Dell computer and does
You can definitely reset the password for your computer just do the ff steps:
  • when the computer is starting up press F8 simultaneously
  • select safeboot when prompted for boot options
  • login as administrator
  • when you are on the main screen click start
  • select control panel
  • select USERS
  • select the username that you are using
  • click on remove password
  • then restart your computer
Hope this will help
Thanks
Byron
Posted on Sep 24, 2009
ag66339
  • 127 Answers
SOURCE: gateway login screen
Restart the laptop, hit F8 repeatadly to start in safe mode. This will bypass XP's login screen. You can then manipulate the password in the control panel. Also, you can change it by going to commandprompt2.gif, type: net user * (your username) then whatever password you want.
Posted on Oct 22, 2009
How do I find or reset my password
this is not face book so a photo of you is not required
follow the user manual to reset the password
Sep 05, 2017 | Computers & Internet
How to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
Jun 20, 2012 | HP ProBook 4310s Notebook
How to reset Windows 7 password?
The easiest way to reset forgotten Windows password I ever use is to use Windows Password Reset Deluxe,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
May 29, 2012 | E-Machines Computers & Internet
I forgot my windows 7 adminstrator password
Windows Password Unlocker can help you reset forgotten Windows local administrator, domain administrator and other user account passwords on Windows 8/7/Vista/XP/2008/ 2003/2000.
Jan 18, 2012 | Microsoft Windows 7 Ultimate 32 bit Full...
How can I reset a forgotten password in windows 7 64 bit home premuim
Resetting the password on windows systems is easy. Because this method may be used for illegal purposes, you may only use these on your own computers.First step find a computer whith which you can access the inter/burn CD-s.Step two download a bootable password recovery solution such as:L0pthcrackBacktrack (complex)Active@ password recoveryor the simplest:http://www.windowsloginrecovery.com/windows-7-password-recovery.html
Step three: burn CD/create falsh driveStep four: boot the forgotten password coded computer from the CDStep five: folow the onscreen instructions
Nov 10, 2011 | Compaq Presario 700 470024-192 Notebook
Forgot my login password to Windows 7
What if you forgot windows 7 password by accident? How to crack windows 7 password by yourself? Try this
wonderful SmartKey Windows Password Recovery as soon as possible. The same as Windows 8 password recovery tips.
Step 1: Download and install, run the program on a unlocked computer.
Step 2: Burn a bootable CD/DVD/USB Flash Drive with the program.
Step 3: Reset Windows password by the burned CD/DVD/USB Flash Drive.
Now it has promotion until Jan 15th,2013
http://www.recoverlostpassword.com/promotion/christmas.html
Sep 08, 2011 | Computers & Internet
I have a sony laptop vaio, i need to break the pass wood to unlcuk it, what can i do
Hi ilvaide.
I hope you are referring to the Windows login password.
If I'm correct, let me explain you about the trick to reset the Windows login password.
You may reset the Windows login password by using the Application "Ophcrack".
This Application will reset the Windows login password without deleting any personal data in the User account.
Let me explain you the procedure.
1) You may download the Application from the below link:
http://ophcrack.sourceforge.net/download.php?type=livecd
2) Once you have downloaded this Application, please mount the image by using any CD/DVD Mounting Software(Power ISO, Magic ISO etc.,).
3) Then, burn the image to a CD or DVD.
4) Now, please follow the steps which is mentioned in the below link.
http://pcsupport.about.com/od/toolsofthetrade/ss/ophcracksbs.htm
As there are a lot of steps, I have mentioned the direct link.
However, the link has the detailed information including some screenshots.
Please follow the steps mentioned on the page to reset the Windows login password.
Hope this helps.
Please feel free to ask further questions.
Aug 21, 2010 | Sony VAIO Notebook
Forgot log in password
Don't worry when you forgot administrator password. I realize an easymethod to remove windows password,it need no computer skills and no reinstalling windows. Google Windows Password Seeker or passwordseeker.com. Maybe thiscould help.
May 19, 2010 | Microsoft Windows XP Home Edition
I FORGOT MY SECRET QUESTION TO RESET MY NEW PASSWORD
Power on password or login password?
To reset
1 Power on pass-call and go to HP Service Centre (better with proof of purchase) or to laptop repairman.
2 Login pass to OS - use EDR Commander and put new one
Good luck
Sep 11, 2009 | HP Pavilion DV7-1020US Laptop
Forgot password for vista login
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jul 08, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
