Question about Philips 818564 LivingColors Mini Color-Changing LED Ambiance Light
Lamp living colors plug - Philips 818564 LivingColors Mini Color-Changing LED Ambiance Light
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Colour wheel and lamp replaced on DLP tv,--lamp will not illuminate,fans and colour wheel working.
first, the color wheel should not operate if the lamp does not come on; if YOU replaced the wheel yourself double check something.
There are two cables from the color wheel, one is a typical plug and the other is a flat ribbon cable, the ribbon cable has connections only on one side as it plugs in: it is very easy to plug it in backwards in which case lamp will NOT come on at all.
SD TECH
Mar 31, 2011 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
I have two dlp infocus X2 projectors. Both of them have lost their color. Is there something I can do to fix it?
This could be one of 2 things. It could have a bad color wheel or there is a setting problem in the unit. If the video mode is not set correctly like NTS or PAL it can give a black and white image.
The other could be your color wheel has failed. Did the unit make any noises before the color went out?
Some times the color wheels will make noises when the age before they crack or break from the heat.
I believen you can pull the lamp out and with the lamp out try and power the unit up, look into the little hole the lamp shines into and see the color wheel spinning. when you first plug it in and unplug it the wheel should spin and you should see the colors change. DONT TOUCH THE COLOR WHEEL they are fragile and can break easy. Some get more brittle over time from the heat of the lamp.
May 19, 2010 | Compaq MP2800 Microportable Projector sps...
I need to know the color of the tail light wire in 2004 mit endeavor, color of the left turn, color of the right turn, and ground.
if you get a little test lamp turn on your tail ligts and use test lamp to find the one wire that your tail light switch is making live and also do the same with turn lights one at a time should figure them out
Apr 04, 2010 | 2004 Mitsubishi Endeavor
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
I have a 62 " flat panel screen. The tv has sporadically turned it self off and then back on. It then stays on for hours with no problem. In January I had a repair man come and he determined it had a...
First check your lamp and make sure its good, look at the glass in front of the lamp for cloudyness and or white spikes. Look at the base of the bulb in its housing if its buldging replace it. If new lamp does not repair then you may have to replace the Optics Engine. But check ur lamp first, Also when color wheels go bad they make a loud whining noise when they are going bad. The tech may of just wanted to replace your entire engine for more money knowing you may just need a new lamp, If you have had the tv for at least 2yrs without replacing the lamp, then its time for a new one..
Have any Questions: Email me at:
Delhielectronics@live.com
Sep 25, 2009 | Televison & Video
Samsung Dlp- Lamp does not turn on
You most likley have the little copper colored flat ribbon inserted into the plug backwards.Filp it over this should fix your problem.Common mistake.
Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Lamp blew, I replaced it, still no picture.
Are you sure the lamp was bad? Try using a different color's lamp board plugged into the problem lamp for a test. If it now works, then the problem is in one of the circuit boards, prob the one that plugs into the lamp.
Nov 13, 2008 | RCA HD52W59 HDTV Projection Television
Philips 818564 LivingColors Mini Color-Changing LED Ambiance Light Logo
52 people viewed this question
Top Philips Home Security Experts
Andrew Taylor
Andrew Taylor
Bosse Photos
Are you a Philips Home Security Expert? Answer questions, earn points and help others
