Question about iRobot 5800 Scooba Vacuum
IRobot Scooba 5800 "check tank" light
I am hoping to buy a used Scooba 5800. The current owner has had it stored for a while, and it worked fine before storage..now it needs a new battery bc it will only last a few minutes. The check tank light is on. She swished the tanks with water and primed the pump. She said there was a service error telling her to clean the bumper, which she did with a q-tip, and now the service light is on but the check tank light remains. Just wondering if anyone has any more ideas on what the problem may be? And wold it be worth the $65 + cost of new battery to gamble? Thanks!
  • Trisha Marsh
    Trisha Marsh Dec 31, 2013
    *service light is OFF, check tank light remains on.
  • Trisha Marsh
    I just noticed on the pic sent that it looks like the long part of the squeegee is missing...would that give a check tank error?
    Top Expert:
  • iRobot Master
  • 34,821 Answers
Why buy something used that is not in perfect operating condition? There may be other problems yet to be discovered.
Posted on Dec 31, 2013
4 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Scooba 5800 Power button Red Blinking
You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
Posted on Aug 06, 2007
taran_2005
  • 10515 Answers
SOURCE: Scooba in diagnostic mode
This is a common issue :)
his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
  • Remove the battery and power.
  • Remove the two screws holding the bumper shell in place and remove it.
  • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
  • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
  • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
  • Check to see if it works again. If not, repeat.
  • Replace the bumper shell and screws....
thnx.
Posted on Jan 25, 2009
  • 61 Answers
SOURCE: It keeps telling me check tank
Prime Scooba's pump, as described here, but use water instead of air to prime the pump. Water is more effective. You'll have a little puddle under the robot if you've been successful.
Then rinse the tank through all four ports on the underside-- one round, two oval, one large and curved. All four are in a row at the bottom of the transparent area. You'll probably dislodge some clots of debris and sediment. Then refill the tank and run the robot. That ought to do it. If it doesn't, call customer support at 1-877-855-8593.
Posted on May 29, 2009
Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | iRobot 5800 Scooba Vacuum
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
Scooba now stops sooner and isn't finished cleaning :-(
I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
Hope this helps.
Jul 17, 2009 | iRobot 5800 Scooba Vacuum
NO water coming out of Scooba.  It's moving and rotating, but not emitting water.
Here's what worked for me.
Use a drinking straw to blow on the solution valve (next to the battery under the tank). If that doesn't work, try blowing a bit of canned air on the solution outlets on the bottom of the unit (in the trough in front of the brush).
Others have suggested using hot water to clean the solution and dirty tanks.
Jun 27, 2009 | iRobot 5800 Scooba Vacuum
When i charge,the service light is on and beeping
get back to the person that you bought it from i would think they would give you some kind of waranty.i don't trust buying from ebay .i hope you didn't pay a whole lot for it.send an email to ebay themselves.please leave feedback
May 04, 2009 | iRobot 5800 Scooba Vacuum
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
I have a new scoba (irobot) the battery is charged the tanks were fillied and every time i hit the power button and then clean the machines "check the tank" light came on. i have done all the...
we had to prime the sensor. irobot suggested a turkey baster, but we didn't have oneso we used an empty visine bottle with the end snipped off and rinsed completely. this worked after the first try. thank you for your interest
Apr 18, 2008 | iRobot 5800 Scooba Vacuum
Aug 06, 2007 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
124 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
